Drifting as a beginner?
Duke137
Post Sun Feb 05, 2012 9:50 pm
Was thinking of turning this into a DWYB type car all in the name of "a laugh" :)
I pretty much have everything to hit the ground running, all 'SE parts' will be removed and kept/sold as necessary, I have a spare engine, about 12 spare wheels with tyres I could destroy, 3 spare diffs and a welder. The car has been lowered 55mm and being the 4 door variety is bridge fodder anyway I figure what the hell...
Wasn't planning on going mental spending loads of money as being a 320i I was thinking if it goes bang then it goes bang but is there anything blatently obvious I am missing? I know I should probably stick bucket seats and harness in for good measure. Engine has had a recent oil and filters and plugs but wasn't planning on going down the route of a new timing belt or anything expensive (it's just a b20)
Any tips/advice would be great as it is just a random idea I have had and as yet I haven't put much thought in. The car won't be doing track days just drift days with a couple of mates joining in using it and paying for fuel and any bits it might need.
Phill172
Post Mon Feb 06, 2012 9:14 am
New oil/filter
Electric fan on a switch
Check the cooling out (viscous, stat, fluid etc)
Weld diff
Lots of tyres with lots of psi
Skid
maxfield
Post Mon Feb 06, 2012 9:18 am
Steering rack is always a good modification if you can find one cheap enough.
If not get some rack spacers, these help a lot. I used 2 x 2 Euro coins per side.
Duke137
Post Mon Feb 06, 2012 9:42 am
cooling system is pretty sharp on this one already, is an electric fan on a switch worth the effort?
@ maxfield, where do you fit rack spacers? Sorry for being dumb. I just sold an E46 rack but I will make do with the 'windmill spec' rack for now.
Thanks for the tips 8)
Phill172
Post Mon Feb 06, 2012 9:50 am
Duke137 wrote:cooling system is pretty sharp on this one already, is an electric fan on a switch worth the effort?
Yes for something that can take 10 minutes to sort
im not being a dick and saying you cant drive but if your a beginner your first day will be 90% spent going round in circles or doing figure of 8's. So not really going very fast and working the engine hard.
I say this to everybody with a bmw, because bmws HATE going round in circles. They overheat so fast.
The worst thing at a drift day is to have a overheating car and having to wait for it to cool down
If it was my car id have the thermostat out and drill it with a few holes too.
As a beginner id just sort those bits out and go out and skid, see if you like it and see if you get on with it.
As maxfield said rack change is always good as the e30 rack is shite, lock to lock your arms will be flapping like mad!
maxfield
Post Mon Feb 06, 2012 10:02 am
The go between the tie rod and steering rack for some extra lock.
Duke137
Post Mon Feb 06, 2012 10:06 am
Cool (literally) I will set up an electric fan aswell then 8)
Cheers lads :)
