'Groaning' on turning right
George
Post Sun Feb 05, 2012 5:45 pm
Any ideas? Typically occurring on going round roundabouts or right into junctions. Seems to emanate from the right rear.
Been going on for the last couple of months but admittedly owing to issues as work, not had the chance to get the car jacked up to have a look.
TIA :)
fuzzy
He who sleeps with "Gingers"
Post Sun Feb 05, 2012 5:48 pm
wheel bearing by the sounds of it.
mrLEE30
Post Sun Feb 05, 2012 6:22 pm
If it happens on tighter turns at slower speeds I would say the diff.
Wheel bearings tend to make noise in situations like changing lanes or higher speed corners.
George
Post Sun Feb 05, 2012 7:39 pm
Interesting. It's a low pitch rumbling groan. My first impressions were perhaps the right rear CV joint?
kam-325i
Post Sun Feb 05, 2012 7:41 pm
George wrote:Interesting. It's a low pitch rumbling groan. My first impressions were perhaps the right rear CV joint?
RWD CV joints dont go like those on FWD.
George
Post Sun Feb 05, 2012 7:45 pm
Ah right. I mentioned the above as we used a Rover for a charity rally and it displayed very similar symptoms and that was diagnosed as a CV joint.
kam-325i
Post Sun Feb 05, 2012 7:55 pm
A CV Joint will "Clunk" when it wears. But RWD CV joints are not stressed like those on FWD cars, you could used a simple UJ instead.
What you have described sounds like a wheel bearing problem.
George
Post Mon Feb 06, 2012 1:46 pm
kam-325i wrote: What you have described sounds like a wheel bearing problem.
How is it best to go about confirming that the bearing is the problem?
Grrrmachine
E30 Zone Wiki / Team Member
Post Mon Feb 06, 2012 6:08 pm
Normally, you jack that wheel off the ground and then give it a good tug side to side, and up and down. If it wobbles relative to the strut, then it's usually a dead bearing.
Demlotcrew
Post Tue Feb 07, 2012 3:45 pm
Take it to a professional! Cant say i have even been able to feel play in a bearing. 8O
George
Post Tue Feb 07, 2012 7:06 pm
Many thanks for the input, will check it out.
Hopefully it'll have warmed up and the snow melted by the weekend.
fuzzy
Post Tue Feb 07, 2012 7:20 pm
theres only the once where ive been able to wobble the wheel side to side . if you can do that its near the point of total disintegration.
