Hey folks I am looking for a new set of tyres to stick on the Alpina replicas on my e30 cabrio but I was wandering if there is a particular model that works well on the e30
Also currently the tyres are 205/40/17 - I noticed that the inside rim of the alloy was showing so would it be okay to go for 215/45/17 for a wider track and thicker tyre wall so it takes bumps better... the car has koni springs and shocks so its been lowered around 25mm f n b
any help would be massivly appreciated.
Z
Tyres recommended for an E30 CAB
- Mad-tango-geezer
im using 215/40/17 , im on a 30mm drop, i wouldnt go with the 45 profile it changes the rolling radius, as for make, its down to your buget
with cars like mine,
Thanks for the reply mate... ill go 215/40 on toyos proxy t1-r c
I had 215/45 17s on my reps and being lowered 60 mm the tyre rubbed on the front wing..
I changed to 215/40 17 and never had any issue
IMO, the 215/40 looks better than 205/40 as the 205 give the rim a bit of poke and it looks as if the tyre is too small or the incorrect size.
E30 Crazy!
