oh god! guys, i found the stupid 0.13 amps drain. it was nothing on the fusebox.
check this out: it was a relay with 3 ground conections, the positive lead going from the alternator, and another lead that went to a switch in the dashboard, and the other lead from the switch down to the brake pedal sensor(the one that detects if the brake pedal it's pushed or not)
now i isolated the positive lead from the alterator, seems its been "a home made connection", and the problem was solved. turns out that relay was draining 0.13 amps constantly. i have no idea whatsoever about the role of the relay, the guy i bought the car from, said it was something that had to do with the abs, but it has nothing to do with that. it was basicaly a positive lead from the alternator and three earth conections, plus that crappy switch circuit that does nothing.
weird stuff. solved, now the amperage looks like this: 0.05 amps, when i first make the connection to the battery and in 10 second it drops to 0.00 amps. so no drain.
