sweep
sweep
Thu Jan 26, 2012 6:22 pm
Its getting fettled back up to scatch first of all
Thu Jan 26, 2012 6:25 pm
sweep wrote:And its not a breaker.
Makes a change pete
Thu Jan 26, 2012 6:30 pm
You got one then pete
correct me if i'am wrong didnt you just break a calypso red one
assume it was fecked
sweep
Lukai
Fri Jan 27, 2012 1:55 pm
Nice... finally got yourself the decent calypso 2 door you wanted! Looking forward to seeing the progress!
Duke137
Fri Jan 27, 2012 2:02 pm
Nice one Pete!
Get it Peado'd
BTW What's the spec?
sweep
Fri Jan 27, 2012 6:16 pm
Thes spec is irelivant at the moment...
sweep
Fri Jan 27, 2012 10:12 pm
Cant wait to ge started once the weather drys up and im not running allover the place with parts!
tonybtonyb
Sun Jan 29, 2012 2:59 am
good luck with your new toy
sweep
Mon Jan 30, 2012 10:54 pm
Got this running right today set and cleaned throttle body,replaced cap and rotor arm.and replaced a faulty idle control valve and blue temp sensor.onwards and upwards ....
sweep
Mon Jan 30, 2012 11:03 pm
Now now mr13, no need for sarcasm....it has a humble but in good fettle 316i motor,now the truth is out but,, and i must stress but ive had it on the ramp today and the shell is good and never been welded.
sweep
Thu Feb 02, 2012 7:04 pm
Minor update now with 15 inch bbs wheels
Thu Feb 02, 2012 9:02 pm
it won't be staying 1.6 i guess! 105 horses don't cut it
sweep
Thu Feb 02, 2012 9:17 pm
springs and e92 front top hats have landed, i have removed the inner boot trims and its all good in there,im now wire brushing the rear arch lips out.
colour magic'd it today ..
Thu Feb 02, 2012 10:50 pm
e30topless wrote:Alex wrote:M52 pete ?
Pete is old school, m20 FTW
Fair enough
Do you have an e30 anymore Steve ?
Thu Feb 02, 2012 10:53 pm
He's got enough old skool powered chariots, time for something with some proper grunt
yep, 17
i dont mean on the racking
I thought you had the m3 your restoring and the hartge jobby.
Ah the 333i forgot bout that
whats the rest then
Thu Feb 02, 2012 11:00 pm
yep, 17
whats the rest then
lots of mundane scrap, Latest is a mineral blue moredoor
back on topic I caught up with Pete the other day tis a fine chariot this one
Thu Feb 02, 2012 11:03 pm
e30topless wrote:Alex wrote:e30topless wrote:
yep, 17
whats the rest then
I dont even need to ask what your doing with that. mineral blue moredoor is enough
Back on topic
will be interesting to see the drop with the e90 top hats. suspension is next on my touring
Sat Feb 04, 2012 7:52 pm
sits well, any side views ?
sweep
Sat Feb 04, 2012 8:13 pm
front seems a little high? or will that settle after a while
sweep
Sat Feb 04, 2012 8:17 pm
The car is actually level but the front arch lines are higher than the rears and this was taken just after it was taken off the ramp so possibly may settle a little.
Sat Feb 04, 2012 8:18 pm
Fair enough, will this be this years pod chariot then
- E30 Zone Meets/Events Team
Sat Feb 04, 2012 8:19 pm
Needs a 6 pot up front Pete. to lower the front down.
