fuel pump humming
ac
Post Sun Nov 20, 2005 4:30 pm
Dose any one know if it's normal for the fuel pump to hum quiet loud on a 318i cab 92 spec.
Both when idleing and driving.
Ac
michael24m
Post Sun Nov 20, 2005 4:50 pm
:? mine too, same idleing and driving. whatever you do don't replace it with a pump for a diffrent engine than 318, i tried this and didn't work, the engine didn't start. i put my old one back in and still driving with it. the sound, goes away and sometimes comes back humming i just ignore it.
dasparkybad
Post Sun Nov 20, 2005 4:52 pm
fuel pumps usually become noisy when the motor bearings begin to fail maybe time for a new one before it fails completely
ac
Post Sun Nov 20, 2005 4:56 pm
thanks.
ac
Post Sun Nov 20, 2005 4:58 pm
yes once they get loud they are no longer for this world. I had one go on me on my old 318i not fun!
eko
Old timer
Post Sun Nov 20, 2005 5:17 pm
Mine too was very loud,bought one off " DAN318is" and its been perfect ever since!
Took about half hour to change,very easy job :)
Simon
Post Sun Nov 20, 2005 6:43 pm
I also had a buzzing pump, and changing it for a new one made a noticable difference.
Fuel pumps are common through the E30 range as long as the injection systems are the same.
Micheal, can't understand why yours didn't work, dodgy pump?
michael24m
Post Sun Nov 20, 2005 7:52 pm
i have the 320i engine, and replaced the pump with a 318i pump, same injection model L-jetronic. i seen the 318 drive that day before i took out it's pump and put it in mine.
on the 318 worked wonders not a sound. but when installed on mine, cranked for half a day, couldn't manage to start the engine.
put in my old pump and started from the first key turn, so obviously there was a problem fitting a 318 pump on a 320i :? i think it might have been a pressure diffrence problem.
haffeel
Post Mon Nov 21, 2005 4:32 pm
guys, my fuel pump also makes whining noise at high pitch. I notice when I just come to a hault after a long jurney and did not cut off the engine. when I put down the windows the sound is very obvious.
my ride orignially is a 320i and I have done a 325i conversion.
Are the fuel pump for 320i and 325i are same?
or do I have to install a 320i pump once again as thats the original spec right now?
what ever, I am pretty scared going off long distance. I would like to carry a spare fuel pump for what ever reason.
TQ
Simon
Post Mon Nov 21, 2005 5:37 pm
haffeel wrote:guys, my fuel pump also makes whining noise at high pitch. I notice when I just come to a hault after a long jurney and did not cut off the engine. when I put down the windows the sound is very obvious.
TQ
If the car is a motronic then they are the same....even the same as 316i/318i, the pressure is regulated by the erm fuel pressure regulator :lol:, but I'm not sure about the L-jet cars.
haffeel
Post Tue Nov 22, 2005 3:31 pm
thanks, yes mine is a Motronics 173 series aka 1.3 so I can fix in 320, 325, 318 or 316 great.
