Turning Service Light Off
bassjamm
Post Thu Feb 02, 2012 1:21 am
Hi there,
Apologies if this has been asked before, I'm new, did a search, but nothing showed up.
Does anyone know how to turn the service light off? The car was recently self-serviced, but didn't have the light turned off...argh!
I found this guide, but somehow sticking a paper clip in some holes sounds a bit risky to me, unless anyone can give it the all clear?
http://www.bimmerfest.com/forums/showth ... p?t=327491
Thanks in advance.
Jamie
ali50ferrari
Post Thu Feb 02, 2012 2:04 am
Here you go mate page 2 half way down i done it to my cab looks very similar to what you have described in the url u have added also, on my one it shows how to do the fuel filter aswell. Goodluck
http://www.e30zone.net/modules.php?name ... c&start=25
The preacher is pious lord, for he is scared of hell, where as me I sinned freely trusting in your mercy
mrLEE30
Post Thu Feb 02, 2012 3:56 am
To reset you must ground pin 7, this can be done in a number of ways I.e short pin 7and19 or pin 7 and 11 (my choice) or pin 7 to any bare metallic part. I use a short piece of wire stripped at each end, but a paperclip works too. Some say use a fused wire incase you are not intellegent enough to identify pin 7 and a metal part. The pin numbers are next to the pins in the later cars(very small text and use a torch) and on the early cars the pin numbers are on the cap- but note they sit over the pin when the cap is FITTED.
The procedure is
1 ignition off , ground pin 7 in any way above.
2 ignition on but don't start - your dash lights should be on.
3 wait several seconds the lights should go green
4 turn off ignition.
5 if the oil inspection light is on then turn ignition on again and wait about ten seconds and that will extinguish the inspection light.
6 ignition off
7 remove the ground on pin 7, replace the cap.
Post Thu Feb 02, 2012 8:51 am
Pin 7 is very easy to identify on facelift cars without straining your eyes peering at miniature numbers. It's the one on the outside row, right in the middle of Pacman's mouth.
mrLEE30
Post Thu Feb 02, 2012 3:49 pm
kids these days will have no idea what Pacman is Brian. Maybe refer to it as the Apple logo or similar?
kam-325i
Post Thu Feb 02, 2012 3:52 pm
mrLEE30 wrote:kids these days will have no idea what Pacman is Brian. Maybe refer to it as the Apple logo or similar?
Apple what ??
mrLEE30
Post Thu Feb 02, 2012 4:04 pm
Thing that keep doctors away.
bassjamm
Post Fri Feb 03, 2012 6:46 pm
Just sorted this...thanks for all the help with it guys, nice easy job!
