E36 2.8 sport advice needed right now!
macas
We are actually having a look at a sports right this second and it has severe gunk on the oil filler cap,now iv heard that it us common to have a bit if its been left sitting for awhile but there is a severe amount,what so you reckon??
Tia
Tia
rix313
Any signs of oil in the coolant?
Is there any on the dipstick?
bodger
if its severe the engine may have been cooked, check the coolant for any oily residue
macas
Theres no gunk on the dipstick,cant really tell if theres oil in the coolant,theres no excessive smoke qnd tge engine runs fine.
bodger
what year car is it?
macas
Its 97 on a P reg,
rix313
How long has it been stood for? Both mine and my GF's cars do good milage but still have shockingly gunked up filled caps. Doesn't always mean doom. Only way to know for sure is to go back with a compression tester.
macas
It has full bmw service history aswell,the last sevice was 3000 miles ago and the engine has done 97000
bodger
nikasil or replaced?
It could be the cyclon valve/oil separator valve is blocked. They are a cheap fix to replace.
macas
The engine Hasnt been replaced,no.
Thanks for help so far
macas
The guy said it had stood for about aweek,rix313 wrote:How long has it been stood for? Both mine and my GF's cars do good milage but still have shockingly gunked up filled caps. Doesn't always mean doom. Only way to know for sure is to go back with a compression tester.
If they stand around or do short journeys then condensation can build up in the cam cover and under the oil filler cap.
If there are no other signs of coolant/oil mixing then don't worry about it.
macas
We have bought it,thanks for the input,now fingers crossed!!
Is this for your Bro?
My E36 Touring had a bit on the oil filler cap when I bought it - had been stood at the dealers for a couple of weeks.
Cleaned it off and started using it and it never came back.
macas
Haha youv got a good memory!!E30BeemerLad wrote:Is this for your Bro?
No,its for me mate,just gona start the two hour journey home!!
Stay by the keyboards guys!!
You mean there's no warranty, outrageous
kam-325i
Still going ???
macas
The heaters not blowing very warm!!!!uh oh!
kam-325i
is the temp gauge showing up to temp ?
macas
Temp is half way at the mo
kam-325i
whats the blower like on full whack ?
If the cabin pollen filter is blocked, it can make the heater seem crap...
Very common for the filter to be blocked as its not often changed on E36's.kam-325i wrote:whats the blower like on full whack ?
harry_p
which is daft as it's a 5 minute job
cheers,
harry
harry
In this cold weather, mayo on the oil filler cap is quite common on little-used cars.
macas
The heating is not as warm as it should be on full whack,also top rad hose dosent feel like it has any pressure in it,we can squeeze it quite easily,is this right?
harry_p
in this weather it's probably barely having to use the radiator to keep the engine to temperature so it's possible the systems not getting hot enough to fully presurise.
cheers,
harry
harry
Could be worth bleeding the system, and checking the thermostat is working as it should or is even fitted - some bodgers remove them altogether!
harry_p
heater valves are known to stick on e36s too, they can be removed and cleaned up.
cheers,
harry
harry
macas
Got it home safe and sound,the heating did warm up quite alot when we were nearing home,and the engine temp didnt go above halfway, so it sounds like a goodn.
Thanks again for the advice
Simon
Check my post about halfway down, when the CCV gets blocked up, it can make the problem a lot worse.
Cleaning it out sorted it out for me.
macas
Thats how much gunk was on the our filler cap last night!
I take yours has cleared itself up and hasnt returned?
Also at idle Its ever so slightly lumpy,not severe but noticable,air leak?
Again thanks for the replys
Simon
Yes, it cleared up. It was used for a lot of short journeys beforehand, so that probably caused it.macas wrote:Thats how much gunk was on the our filler cap last night!
Also at idle Its ever so slightly lumpy,not severe bult noticable,air leak?
If it's lumpy they yes, more than likely an airleak. CCV is a common fault on these causing airleaks.
