'88 325i Touring #001 resto - 03/2012 rimz porn
Kedge
Post Tue Jan 31, 2012 5:59 pm
Good stuff there as always Rob, you're right though, that bay needs a damn good clean to match those shiny blasted parts!
Instagram - Kedge85
Post Tue Jan 31, 2012 6:42 pm
TFR and a 2" paint brush to get in all the gaps and shift the dirt/grime.
Post Tue Jan 31, 2012 6:49 pm
Did you allow it to idle for at least 10 minutes to enable the base idle settings to be learnt?
Post Tue Jan 31, 2012 7:16 pm
Speedtouch wrote:Did you allow it to idle for at least 10 minutes to enable the base idle settings to be learnt?
No :o:
Didnt know I had to :o:
Do I need to now re-set this in some way or just let it idle for 10 mins and it will sort itself out ?
Post Tue Jan 31, 2012 7:24 pm
Good job Rob! It'll drive so much sweeter.
Post Tue Jan 31, 2012 9:32 pm
Ideally, you should disconnect either the battery or ECU, leave it for an hour or so to reset, then reconnect, let engine idle for at least 10 minutes, then switch off, then take it for a drive throughout the rev range.
This ensures full transfer of all the EPROM program into the ECU processor.
Post Tue Jan 31, 2012 9:35 pm
Glad its running ok!
Post Tue Jan 31, 2012 9:40 pm
Speedtouch wrote:Ideally, you should disconnect either the battery or ECU, leave it for an hour or so to reset, then reconnect, let engine idle for at least 10 minutes, then switch off, then take it for a drive throughout the rev range.
Cheers for this. I can disconnect the battery and then reconnect it all up and let it idle - but taking it for a drive through the rev range will have to wait until after 1st of April when it gets taxed :(
Simon13 wrote:Glad its running ok!
Cheers - me too :D
TouringMatt
Post Tue Jan 31, 2012 10:31 pm
Good stuff fella :cool:
Post Sat Feb 25, 2012 7:51 pm
Showed the turd some daylight today :D
I think I'm destined to have a mucky engine bay forever :(
brushed in a load of TFR, jetwashed it - once it dried it didnt really look any different :x
Its not perfect along the seam under the washer bottle either - the usual spot - will need attending to at some point. Have painted it with waxoyl for now and put it on the list :roll:
Put the bonnet back on
Leather cover for the gauge pod is an excellent match for the console - might tackle the wiring tomorrow - really pleased with how this looks :cool:
Dezzy
CR24v it's a lifestyle
Post Sat Feb 25, 2012 8:28 pm
Interior looks cracking Rob! :cool:
Post Sat Feb 25, 2012 9:12 pm
Cheers Dez - not long til its taxed and on the road now :D
Post Sat Feb 25, 2012 9:34 pm
Much better with some sorted seats and a proper headlining 8)
Jim320i
E30 Zone News / COTM Team
Post Sat Feb 25, 2012 11:10 pm
Looking forward to seeing this again fella :cool:
Post Sun Feb 26, 2012 12:39 pm
Looking great! Engine bay doesn't look too bad for 25 year old original.
Post Sun Feb 26, 2012 6:38 pm
Spent most of this afternoon wiring up the VDO gauges in the console.
Cannibalised the VAG loom to use the plugs & bulb holders - actually very simple to wire up.
Did a proper job with soldered joints and heatshrink - not bad even if I do say so myself - I havent used a soldering iron since Technology at school - over 20 years ago 8O
First couple were a bit messy but cracked it after that 8)
Had to order some new instrument bulbs as 1 was blown so no pics yet until its properly in and it all lights up as it should.
Then just need to test it to see if the temp sender supplied is indeed the right one - pressure gauge seems fine and puts the light out as it should when the engine is started as well as a proper reading.
Only slightly annoying thing was having to cut the carpet under the ashtray hole to allow enough clearance for the gauges with the plugs attached :cry: Still you wont see it when its all in.
Just need to do a bit of tidying with some cable ties for the engine bay wiring and its done.
Am considering taxing it on 1st March rather than waiting til 1st April - I cant wait to drive it - just means I'll have to SORN it on 1st September rather than 1st October for the winter.
Also needs a bloody good clean inside & out :D
Speedtouch havent forgotten about getting a chip off you - will be in touch soon :wink:
Post Sun Feb 26, 2012 6:40 pm
Remember Santa Pod is Mid September Rob :D
Jim320i
Post Sun Feb 26, 2012 6:54 pm
Alex wrote:Remember Santa Pod is Mid September Rob :D
24th...
Just wait and stop being impatient! :twisted:
Post Sun Feb 26, 2012 7:31 pm
Rob, 12 months ticket is cheaper than a pair of 6 month ones, you also get more back when you weigh it in for winter. I never buy 6 months because I hate giving the DVLA a penny more than I need to
Post Wed Feb 29, 2012 8:23 pm
Bloody slow going - done a bit on Monday and a bit tonight
Engine bay almost completely done - everything back in place - just missing a couple of clips that I'm hoping the zone will provide winkeye ( the one on the side of the airbox which holds a wiring loom and the one which mounts to the block which holds the wiring to the oil pressure sender if anyones got them :wink: )
Still trying to sort out the gauge pod - starting to do my head in now. Supplied instrument bulbs must have been on their last legs because all but one have failed - ordered some more off ebay on Sunday night but they havent turned up yet :roll:
Centre console needs to come out AGAIN to trim a bit more carpet away behind the pod to give enough clearance. Finally sorted out how to clamp the gauges in place by cannibalising the Audi metal backplate - just had to trim a couple of bits with the grinder :twisted:
Need to relocate the cigarette lighter into the glovebox area somewhere so I can still plug my satnav in - have got a spare upper trim so might drill a hole in that and mount it in the top.
Central locking still not working too :x
Decided to tax the fooker tomorrow to give me the kick up the arse I need to get it all done so I can use it :D
Also gonna book it in for Tracking on Friday morning so it doesnt eat my tyres :D
Dezzy
Post Wed Feb 29, 2012 8:36 pm
It'll feel very strange driving it instead of working on it mate.
Nearly there now :cool:
G-Bear
Post Fri Mar 02, 2012 9:02 am
Just finished reading through this thread. Very enjoyable. Great work through out. Its helped add another few pages on the 'to do' list for mine...
Looking forward to more updates..
Post Fri Mar 02, 2012 6:59 pm
Got a bit done today - taxed the fooker to start with :D
VDO Gauge pod is done, in and working :cool: :cool: :cool:
Took it to have the tracking checked and get a slow puncture looked at - turns out one of my BBS is scrap :x so got to find another single one and the track rod ends are seized so the tracking couldnt be done today.
Its not that far out but it does need adjusting. Booked it back in for next friday - said they will probably need to get some heat on it to free them off :(
Tidied up the interior, im still short of a few clips and bits but its basically back together.
Only other problem which needs sorting is the idle is very lumpy - tacho is rock steady but its like its got an air leak somewhere but ive checked all the hoses and they seem all good. Also cleaned out the ICV with carb cleaner but made no difference
On the road its ace - super smooth through the rev range and sounds quality :cool:
Just need to sort these last few niggles
Kedge
Post Fri Mar 02, 2012 7:12 pm
Good work Mr!!
Now get yourself over to Jims on Sunday lunchtime, it could do with a blast down the A5. We're having a mini meet, i'm sure you can raid his stash for a few clips etc. There should be me, Jim, Rav, Matt from ECP, Ryan (wingnutleft) and i'm guessing Jim's mate Ricky.
Instagram - Kedge85
Post Fri Mar 02, 2012 7:16 pm
Try soaking the TREs in PlusGas penetrating fluid - repeat over the course of a few days.
Have you checked to see if the ECU has the standard chip?
brettski
Post Fri Mar 02, 2012 7:30 pm
Rob have a word with Mark i've just had a bbs off him and he sorted my track rod ends out took him about 15 mins!
Jim320i
Post Fri Mar 02, 2012 7:38 pm
Good news Rob, get it over to mine on Sunday, you'll be able to explain the clips you need too, I think I have the ones on the air flow box for you. Plus it will be good to see her again since the last time at Cov meet when you first got her 8O
kieran325
Post Fri Mar 02, 2012 7:41 pm
Is the redneck meet still taking place on Sun?
Jim320i
Post Fri Mar 02, 2012 7:42 pm
This Sunday, yes Kieran :cool: You fancy coming too? :D You'll think i'm a gypsy when you see where I live, and you'll be correct :twisted:
Post Fri Mar 02, 2012 8:09 pm
Speedtouch wrote:Try soaking the TREs in PlusGas penetrating fluid - repeat over the course of a few days.
Expect it has but havent checked - ECU looks like its never been tampered with.
I did about 10 miles in it today as a bit of a shakedown to try and identify any running faults but the idle was still rubbish afterwards - like its misfiring - but as soon as you give it some throttle its perfect - weird :?
Still havent tried the ECU reset - worth a go I guess.
Only other thing I did today was to identify why the central locking on the passenger rear door doesnt work - reason - no fookin actuator there ! :x I've got a spare one from the bronze turd which I plugged in and confirmed the wiring works but unfortunately the metal linkage is missing so I need to source this.
Sorry guys would love to have come over to Jims but already got commitments for Sunday :cry:
Post Fri Mar 02, 2012 8:59 pm
kieran325 wrote:Is the redneck meet still taking place on Sun?
Thought you were going to "Redneck" county on Saturday with the other Northern Redneck :D
kieran325
Post Fri Mar 02, 2012 9:19 pm
Yes, I'm up to date with the current injections so I thought I might wander into the deep redneck county before the injections wear off.
It all depends on the weather my friend.
Post Tue Mar 06, 2012 6:32 pm
Few minor bits done today - new clips for the panel that covers the rear lights in the boot, replaced the wiper spindle seal with a new one, fixed the sagging skirt on the passenger side front wing - it appears to have had a replacement wing at some point and whoever fitted it only put 1 grommet in to support the skirt - the one that takes all the weight was missing :roll:
Track rod ends still seized - fire & stillsons next :evil:
Post Fri Mar 16, 2012 2:48 pm
Well as the turd is now pretty much finished for 2012 anyway I've put a sponge over it today for the first time in the best part of a Year - oh and upgraded the rimzz innit :D
Love this pic 8)
Dog-proof :D
Nothing much more planned for this year - theres a few dings in the panels which I'm going to get dentmastered, another oil & filter change when I've put a few miles on it and thats about it - then paint hopefully next Year.
Bit of a change from when I first got it eh ?
Only washed it for now and leathered it off and put it away - might try and get one coat of polish on it this afternoon and take it out to get some proper pics :D
Duke137
Post Fri Mar 16, 2012 2:50 pm
Lovely.
You just need a nice set of OEM Mats in there 8)
