2.7 question
Quaser
Post Sun Jan 29, 2012 10:18 am
Hiya
Im looking to do a budget 2.7 coversion on my cab but cant decide which route to go down.
The choice is either 2.7 block with my 320i head and 325i cam, inlet, injectors etc - or just a 2.7 block with a 325i head etc.
The question is - what are the charcteristic differences between the 2? What bhp/torque would i expect from each one and what are the differences in driveability?
Q
**BANNED**
Post Sun Jan 29, 2012 10:38 am
Piston choice will determine head choice!
Using the eta flat topped pistons is the easiest/cheapest way,just drop the 320/731 head on with your choice of cam inserted.
If you use the 325/885 head,you really should be using the matching 325 pistons,to take proper advantage of the combustion chamber design on this head.This then sends you down the route of modifying the block,as the 325 pistons sit too low on the longer eta con-rods.
Just plonking the 885 head onto the eta bottom will run,but the larger valves of this head will just waste fuel and lose you low down torque.
My 2.7 has now been built for more than 5 years....
Eta crank/rods/pistons
84mm block
731 head
325 stock cam
325 inlet/injectors/FPR
hottuning exhaust manifold
Miller MAF
2.7 chip supplied by Ant,modified by Miller.
Two years back,when the engine was swapping cars,I fitted an ex E21 323 cam.This lost me a little low down torque,but the gains above 3000rpm more than compansate.Car ran even better after Gunni had live mapped it for me.
There is no 'right way' or 'wrong way' to build a 2.7,just the way that you want for your needs.
Youth is wasted on the young.
Quaser
Post Sun Jan 29, 2012 10:40 am
so what bhp/torque output do you have?
**BANNED**
Post Sun Jan 29, 2012 10:51 am
Currently,after Gunni's work last springtime,just under 180ft/lb torque at 4500rpm and just less than 175bhp at 5800rpm.Usable torque(150ft/lb)starts much lower down,though,at about 2000rpm!
This wide spread of torque is what a 2.7 is all about,less need to use the gearbox to get good acceleration for quick overtaking.
Quaser
Post Sun Jan 29, 2012 11:22 am
hmm - i was hoping for more like 190bhp!
**BANNED**
Post Sun Jan 29, 2012 11:43 am
Quaser wrote:hmm - i was hoping for more like 190bhp!
For that,you will need to go the 885 head route!
Dummy build one cylinder and measure just how for down the bore the 325 piston sits,then get the top of the blokck 'decked' by this amount.
Then,because the camshaft will sit closer to the crank than usual,you will need a vernier cam pulley....you will also need an after market cam and a decent BTB exhaust manifold.
This will all add between £1k and £1.5k to your build cost.Tuning M20 is not for those with short arms and long pockets.....
Quaser
Post Sun Jan 29, 2012 12:04 pm
Yep - I know - I have a 'proper' build putting out 225bhp
This was supposed to be a budget build instead of swapping my 2.0 for a 2.5
I can't decide whether to use the 2.0 head with 325 stuff or just have a 325 head complete!!
What's the 325i head + 2.7 block bhp output?? Does it use that much more fuel??
Or should I just put in a complete 325 engine?? Car is a cab auto!
**BANNED**
Post Mon Jan 30, 2012 12:39 am
Look at it this way,you are starting with a 320i....129bhp?
So a budget build similar to mine nets you 175bhp,a gain of 46bhp,or better than 35%!
WTF do you want? :eek: :mad:
Quaser
Post Tue Jan 31, 2012 12:28 pm
or another way - drop in a 325i and get 170bhp for a lot less!
i just dont want a 320 in there basically! Ive already got the 2.7 bottom end - just wanted to know differences between the 2.5 and 2.0 head characteristics.
Ajsingh
Post Tue Jan 31, 2012 3:28 pm
I used a 2.5 head and there is plently of torque and power! Has peed all over an e36 328i, apprently it had a rebuilt head with race cams and so on.. Also pee on e46 330s all day long too
E30 Crazy!
Quaser
Post Tue Jan 31, 2012 4:33 pm
whats your bhp AJ? have you had it rolling roaded? where abouts in west london are you?
e301988325i
Post Tue Jan 31, 2012 6:32 pm
2.7's are a worthwhile upgrade. Don't fret about the bhp, different dyno's read very different, upping the capacity will not result in disappointment.
I said:
e30topless said:
lock the wife in there
Ajsingh
Post Tue Jan 31, 2012 7:59 pm
Im just outside of southall
Bhp wise i have no idea, its never been on the rollers mate
E30 Crazy!
ross2009
Post Tue Jan 31, 2012 10:05 pm
if you want it quick its not bhp you wanna worry about its torque
you seem to be worrying alot about bhp figures, natually the bigger the engine the more torque you will have the 2.7 is a torquey motor like aj mentoned, has pissed over alot of others which aint slow in there own right
Turbo M20
v8 project 6.0 twin turbo
Ajsingh
Post Tue Jan 31, 2012 11:04 pm
ross2009 wrote:if you want it quick its not bhp you wanna worry about its torque
+1
Bhp is pub talk, torque is where the men come into it lollll :)
E30 Crazy!
fowler
Boost Junkie
Post Wed Feb 01, 2012 7:29 am
Q you cheap Git lol! Just bang a "Good" 2.5 in it and few tweeks and you will be up near the eta based 2.7 power, if you are gonna do it proper just build one its been clearly documented how to build a good 2.7 on here loads of times...
I could get one built for you if you so require but it don't come cheap...
EX A-Tech Workshop bitch !!!
gone but not forgotten
Eddie25
Post Wed Feb 01, 2012 1:37 pm
fowler wrote:Q you cheap Git lol! Just bang a "Good" 2.5 in it and few tweeks and you will be up near the eta based 2.7 power, if you are gonna do it proper just build one its been clearly documented how to build a good 2.7 on here loads of times...
+1 My B25 was put together following advice from Ben and Ant and i can vouch a B25 with a cam and its breathing sorted is a very different animal to a standard B25. winkeye
Rust is lighter than carbon fibre.
Quaser
Post Sat Mar 24, 2012 11:22 pm
OK - so i got all the bits, put the engine on my shiney new engine stand, tried to turn the crank and.... nothing - its seized!
I knew it turned before! If the bottem end goosed or what will i need to do to repair it?
Q
ross2009
Post Sat Mar 24, 2012 11:34 pm
Quaser wrote:OK - so i got all the bits, put the engine on my shiney new engine stand, tried to turn the crank and.... nothing - its seized!
Q
which engine is this ? the 2.7 or you got a 2.5 now ?
how long has it been standing it wouldnt have siezed that quick
Turbo M20
Quaser
Post Sun Mar 25, 2012 12:05 am
its a 525e bottom end - i know it was turning before, but i have a leaky roof in my car port and i think some might have got into the block and rusted it up a bit inside!
I havent taken the sump of yet though to have a look - but i cant even turn it with a breaker bar on it!
Q
ross2009
Post Sun Mar 25, 2012 12:26 am
well in that case sounds like the rings have rusted in the bores get loads of wd40 or penetrating oil in the bore and let it soak then try again be careful tho as you could snap a ring
Turbo M20
Quaser
Post Sun Mar 25, 2012 12:32 am
cool - will it be ok as it is or will i need to change something before i use it??
ross2009
Post Sun Mar 25, 2012 12:44 am
if you can un seize it , it should be ok the rings should clean the bore up but really it needs looking at to see how bad the bores are
Turbo M20
fowler
Boost Junkie
Post Mon Mar 26, 2012 11:52 am
Q rebuild it to tight sod ! :D
Andyboy
Alpina Colada
Post Mon Mar 26, 2012 6:17 pm
Run a glazebuster down the bores and reassemble it with new rod bolts. Use an 885 head - after a quick clean up skim the CR will be okay and it will go well enough.
