318i 1993 cabby m40 engine
ok i was doing my cam belt change and i came up against my water pump problem, it was all going good, i started to bolt the 8m bolts in to the lugs of the pump and they both snaped off ?
the pump was seized in, so i broke away the rest of the pump around the housing and it was free but still ain't coming out?
i think that the inner of the pump has seized in there as well?
the outter part moves like it wants to come out ??
so do i go for it and break the rest of the pump up (as gently as i can)
well that the only suggestion i have lol
any suggestion or if anyone has came against this before would be great to get some info on how to get it out
cheers
that was one tight mother F-er
does anyone know how much flex is ment to be on the idler side of the timing belt, this is only the 2ed time doing it and cant mind? its all in time but the idler side just looks to have just a little to much flex??
i will upload pix of belt tomorrow might help
cheers
