318i radiator
blingsta
- Boost Junkie
Morning chaps..
not sure how to describe this accurately, but here it goes..!!
when you take off thr radiator filler cap, theres a little hole around the brim... from knowledge, i know that as the water circulates, water also does a wee wee from that little hole...
what are the symptons if this doesnt happen?
- Homo Hair
No water comes out the hole I'd say..blingsta wrote:what are the symptons if this doesnt happen?
Billwill
Is this an M40 motor?
No water comes out of it ever....water should flow in and out of the plastic expansion tank as needed. Make sure you have a genuine BMW OEM plastic filler cap....dont mess with Pirate parts as the OEM one is not expensive.
blingsta
- Boost Junkie
its a m40.. if there is no wee coming out of that little hole around the brim, does it mean the water is not circulating in the rad? oh and its got a genuine bmw cap
suedenim
I know where you mean but not sure of the condition it happens under, does it happen when you increase the revs?
1982 E21 316 Baltic Blau
1989 318i 2 Door Sterling Silber
Feedback: http://www.e30zone.net/modules.php?name ... highlight=
I would expect a small stream of coolant to flow from the hole at any revs. above 2000 RPM or so.
blingsta
- Boost Junkie
but if the above doesnt always happen Brian, what are the consequences?
issue is, that the heat coming into the car isnt HOT. it feels hot'ish on fan setting 1-2 but on 3-4 it feels a little cooler ? gauge temp shows in between 1/4 and 1/2..
could it be blocked rad or matrix? or shall i just change both ? both hoses to the matrix seem to be the same temp..
i would try a new thermostat
Sounds like you have a lack of flow in the cooling system.
Water pump rotor loose on its shaft, or a nasty plastic rotor breaking up?
blingsta
- Boost Junkie
replaced the water pump last week
also new viscous and thermostat
could the lack of flow be down to it not streaming through that little hole that im reffering to ?
The 'little' hole is the air vent from the top of the radiator core. On six cylinder engines there is an eighteen inch small rubber hose between the rad. and the "little hole" in the coolant bottle, and if this hose gets blocked, the system won't vent properly and overheating will eventually occur.
Never known it to block on a four cylinder, but if it did (which seems unlikely), I would expect similar effects.
The lack of coolant flowing from the hole is not important at all as such, but that, coupled with the heater problem you mention, points to lack of pressure from the water pump.
Maybe the heater problem is a separate, unrelated problem, maybe caused by a partially blocked heater matrix.
Are the heater hoses the correct way around on the bulkhead? The one from the back of the head goes to the bottom stub pipe.
blingsta
- Boost Junkie
I'll double check that Brian, but I have noticed the smallest leak rom the rad so I will change that anyway, the car was sitting for 5yrs before I bought it so blocked matrix wouldn't surprise me..
Apart from any additives to try and clean the matrix, can I just take off the matrix hoses and run a water hose through the matrix to flush it through ?
suedenim
Yes, did you flush the rest of the cooling system, block and rad?
ONLY from the bottom stub to the top. Do it the other way, with any significant flow and pressure, and you'll probably damage the electric heater valve.blingsta wrote: Apart from any additives to try and clean the matrix, can I just take off the matrix hoses and run a water hose through the matrix to flush it through ?
blingsta
- Boost Junkie
Thanks Brian, I might just change the matrix and try my luck..
blingsta
- Boost Junkie
hoses are right way around Brian.. matrix pipes both same temp.. the matrix valve you mention above, what does that do?
Valve is switched on and closes, preventing any flow through the matrix, when the temperature knob is turned to or near fully cold.
High flow in the wrong direction may force the valve closed and damage it.
It's on the LH side of the heater box, and the lower stub pipe on the bulkhead is actually part of it.
