Random engine cut-out and kangarooing at 2000rpm?? WHY ME?!
eddieblunt
Post Thu Apr 08, 2010 11:16 pm
Right, I'm no mechanic, so have no idea to the cause of the problems I’m having with my e30 (318i)
I'm having random engine cut outs when driving sometimes under acceleration and sometimes when just driving at a normal speed. When the engine cuts out I have to roll to the side of the road and then try to re-start the engine, sometimes it fires straight back up and I carry on as normal but other times I have to give it maybe 10 attempts to start up again? Has anyone got any idea what could be causing this or where do I start first with troubleshooting?
Also at all times when driving at approx 2000rpm the car will kangaroo quite erratically until I either let of the gas or increase the revs, any ideas?
Hope someone can help!?
randomspeedfreak
Post Fri Apr 09, 2010 1:12 am
i have a similar problem under '316 stutter'
zoners advised me that it was the fuel pump, and to check the pump by putting a light across it while it was stuttering, to check if it has power....
if course since ive found this out the car has been behaving perfectly...probably waiting for me to need it to work badly enough haha :roll:
danbear
Post Fri Apr 09, 2010 1:48 am
this exact thing happened to my 325. only happened once :/
blingsta
Boost Junkie
Post Fri Apr 09, 2010 2:14 am
definately the fuel pump on its way out, or the fuel pump relay
bmw_pr
Post Fri Apr 09, 2010 2:45 am
What are the normal fuel pump pressure fos 325i
bmw-cammy-e30
Post Fri Apr 09, 2010 4:57 am
same thing happend to my 316 my automatic choke was playin up so replaced it with a manual one
eddieblunt
Post Fri Apr 09, 2010 8:30 am
When the engine cuts out it's as if the key has been taken out, the gauges drop to zero and all the red lights come on?! So does this point to something obvious?
I've also tried to bump start it when it cuts out while the car is still rolling but this always fails.
eddieblunt
Post Fri Apr 09, 2010 9:39 am
I have 2 5pin relays with 2x87 pins and they are both black?
Which one do i replace or shall i just do both of them?
eddieblunt
Post Fri Apr 09, 2010 1:04 pm
Oh, I've found them now! :)
So I've been my local bmw garage and replaced both the white one and the orange one, just for good measure.
No cutting out on the journey, but will keep you updated if it hapens again....
Next thing then, why is the car "kangarooing" at 2000rpm?
I've also noticed today that the fuel needle is moving strangley, sometimes its moves toward empty but then returns slowly to where it was, and i can smell fuel when the engine is running, is this normal?
One last thing, what sort of mileage should i be getting out of £20 of fuel? I'm getting about 70-80miles, surely this is wrong?? I'm not hammering it either!
stup86
Post Fri Apr 09, 2010 2:00 pm
eddieblunt wrote:One last thing, what sort of mileage should i be getting out of £20 of fuel? I'm getting about 70-80miles, surely this is wrong?? I'm not hammering it either!
My 318i was awful on fuel when I first got it.
I replaced the 'blue' engine temp sensor and it sorted the fueling out.
With a didgy sensor, it's like the car is running on choke all the time.
Try replacing that sensor, cost me about £15 from the stealers
Parts needed:
M40/M20 ignition coil with high voltage lead
eddieblunt
Post Fri Apr 09, 2010 3:19 pm
Can you post a photo of the location of the sensor?
choppa7
Post Fri Apr 09, 2010 3:33 pm
from 20 litres I get upwards of 140 miles depending on driving and length of journey
1990 318i Lux
mongomushroom
Post Thu Jan 26, 2012 10:00 am
I know this is an old thread but kangaroo jumping at 2000rpm and cutting out when hammering it happens to mine. the car was in a bad way when i got it and i have sorted out most of the wiring issues which has fixed the cutting out. I noticed knocking in the back end somewhere and saw wear in the diff mount and prop center bearing. I reckon this is the cause of the low rpm kangaroo jumping possibly made worse when there are any running issues.
