Oil change and tappets
cee
Post Tue Jan 24, 2012 1:48 pm
So I'm overdue an oil change, and the engine is fairly tappety under load. Will an oil change alone help this, or are there any products/treatments I should consider using?
1990 Sterlingsilber 318iS - 146 bhp / 192 Nm
Francisco
Post Tue Jan 24, 2012 1:56 pm
Are you sure it's the tappets?
Usually a rattling under load means big end...
maxfield
Post Tue Jan 24, 2012 2:20 pm
Assuming it's a 318iS as it says in his signature.
I'd be saying timing chain rattle as I'm sure they're hydralic lifters...
cee
Post Tue Jan 24, 2012 2:34 pm
Hmmm...
I always thought big end bearings made a low grumble? What I'm hearing is more of a 'chika chika chika chika chika chika' sound kind of like a steam engine.
clipper
Post Tue Jan 24, 2012 2:44 pm
Cue lots of panicing about timing chain idlers and tensioners !!!
cee
Post Tue Jan 24, 2012 2:50 pm
So it's looking like a case of replacing the timing chain?
bodger
Post Tue Jan 24, 2012 4:48 pm
whats the milage on the engine?
cee
Post Tue Jan 24, 2012 6:14 pm
150k
