alternator rebuild
xavier
Has anyone tried to rebuild an alternator for a 6 cylinder e30? Mine is charging OK, but I think the center bearing is ratteling. Is the generator just a generic Bosch one that lots of different cars use, or is it specific to the e30? I know some of the bosch altenators used by VW turn up in a variety of models.
It's very possible that you could find an alternator from a different make that will fit. There are alternators designed to fit on the left side of an engine, and those intended for the right, but apart from that they tend to be very much the same, although pulleys vary to get the belt lined up, and electrical terminals might be different.
CHR1S1990
x-works did a brilliant alternator write up on his M3. Same alternators AFAIK (not sure which models use 80/90A ones).
http://www.e30zone.net/modules.php?name ... &start=350
scroll down the page. heres parts list
http://www.realoem.com/bmw/partgrp.do?m ... g=12&fg=22
xavier
What a great thread. Thanks. I think my bearings are worn as I am getting a rattle from the alternator at about 1500 rpm.
CHR1S1990
No problem. If time is tight, then it's a no brainer to pick one up cheap enough off here. But if you've got some spare time its well worth refurbing it yourself like x-works. Especially considering the price of a new one!
