Knackered Heater Blower
aimlessrock
Post Mon Jan 23, 2012 7:50 pm
After a near complete engine rebuilt on my rest E30 320i Cab (M20) i have her up and running for the first time in 3 years (the last owner ran her into the ground and cracked the block).
I have just discovered that the heater blower is knackered, looks easy enough to remove, assuming its proper knackered (everything else on the engine was) can they be restored/overhauled or is it better to replace?
Post Mon Jan 23, 2012 8:41 pm
Its probably seized.
You need to undo this spring clip - its a pig as you cant get a proper grip on it and cant really get a screwdriver under it to lever it undone. I put a nail through the small hole on the bottom of the clip and used a pair of grips to undo it.
Stand the motor on end and drip oil into the bearings and spin it until it turns freely.
aimlessrock
Post Mon Jan 23, 2012 8:51 pm
many thanks Rob, appreciate the photos...will have a nail on standby!
I will pull it out and have a crack at this.
much apprciated.
Post Mon Jan 23, 2012 9:40 pm
No probs :thumb:
Rtaylor2208
Post Mon Jan 23, 2012 9:53 pm
Easiesr way to get the spring clip off I one of the s shaped screw drivers. The kind for under small things and awkward places. Putting it back on though is still escaping me at the moment
http://www.ebay.co.uk/itm/handy-pack-3p ... 0493261021
Rtaylor2208
Post Mon Jan 23, 2012 9:54 pm
Rtaylor2208
Post Mon Jan 23, 2012 10:00 pm
