525e DIFF?
eko
Old timer
Post Sat Nov 19, 2005 5:48 pm
does anyone know the advantage/disadvantage of fitting a 525e diff to my 318is?
Reason i ask is i have just been offered the full car cheap,and my mate who has a 520i is trying to blag the diff!
Any ideas?
or have you done it? :)
m-dtech
Unapproved Trader caution
Post Sat Nov 19, 2005 6:11 pm
its like 2.93 i think
if u do motorway miles will give good MPG
lower rpm at high speed.
320Touring
Post Sat Nov 19, 2005 6:12 pm
As far as I know-the 525e diff will probably be a "big case" diff with ratio of either 2.97 or 3.05 ish..
Your IS is fitted with a 4.10 (small case) diff as standard, so if changed to a big case you'd need to shorten the propshaft (not a difficult job!)
The big case weighs more, but is more reliable.
however, either a 2.97 or 3.05 will probably be too long for you to use in your IS.
Basically, Accelleration will be reduced (as 525e diff is "longer") but top speed will be higher.
Your m42 high revving 16v probably wont like that diff at all.
hope this helps
Neil P
Dan318-is
Post Sat Nov 19, 2005 6:13 pm
Eko dont do it ul slow the car stupidly, ul inrease economy but thats it
u ideally need a 4.10 LSD (rare and expensive)
or a mid 4.20s LSD of a 318i lux, also rare
some people use 3.91 of tec 2 sport but apparently u can feel acceleration difference!
eko
Old timer
Post Sat Nov 19, 2005 6:15 pm
ok thanks chaps,just making enquiries really.
Good bit of info there
I think ill stick with what ive got!
Dan318-is
Post Sat Nov 19, 2005 6:16 pm
u can homemake a 4.45 diff that wud b the muts nuts (except on motorways)
johnno has 2 for sale, dunno how u wud do it though
eko
Old timer
Post Sat Nov 19, 2005 6:29 pm
cant be arsed stripping and rebuilding it!
Probably just blag my mate with it,make out that im doing him a massive favour!
(Need him to sit in it and tow it winkeye )
