Thatsa the planDezzy wrote:Why so much???318isPMK wrote:No Im at the point we need to decide to shell out for it all.
I want to keep the engine but cant spend 1600 on it!
Max budget is around a grand to 1200 I started with 700 and pushed to top it up to that mark.
Im not happy but i cant keep letting it get to me.
Buy a second hand engine!
I know you don't know for sure that its going to be ok but, You could buy 5 secondhand engines for £1600
HELP DISASTER ADVICE NEEDED!!!!
318isPMK
skipunda
Bit of a shock to the fiancée, going from no e30 to one in bits and a breaker on the driveway!
Chris
318isPMK
Dezzy
- CR24v it's a lifestyle
The two Team members are to be trusted!
Listen to good advice mate. You've wasted enough money (you don't have) already.
snakebrain
+1Dezzy wrote:The two Team members are to be trusted!
Both decent guys..
318isPMK
318isPMK
Rtaylor2208
Boyd had a good 2.5 M20 for sale a while back, would he able to do that conversion for you and keep it in budget.
Grrrmachine
- E30 Zone Wiki / Team Member
While there's plenty of good engines to be had, I'd recommend keeping it as an iS if you ever want to recoup the money you've put into it.
adit
how about an E36 318iS engine? early ones had the same 18/4S1 engines and later the 19/4S1 version. are they compatible for an E30? different inlet/exhaust mani, etc?
[quote="bss325i"]
Andyboy
- Alpina Colada
It already has an E36 engine by the look of it, a post 9/93 motor.
A used head, new chain tensioner and the bare minimum sound better however. It probably won't need sprockets and the chain is probably okay as well.
snakebrain
The plot thickens! So you reckon it's already had a swap?Andyboy wrote:It already has an E36 engine by the look of it, a post 9/93 motor.
318isPMK
Option 1 Full Repair new clyanders x8”“ Won’t exceed £1500 + new clutch 105
Option 2 Repair engine used cylander head”“ Won’t exceed £1350
Option 3 - Unlikely to exceed £1000 ”“ but could be much cheaper ”“ depending on the cost of the engine and whether or not to put a clutch in. We could just put your existing clutch in and it’d be the same ”aclutch risk”a as option 1.
Prices put up by £150 labour already spent stripping down the engine to diagnose
What do you's think??
richard300
325i Motorsport Convertible (For sale)
Jaguar XJ8 4.0 V8 SE
Mercedes CLK Kompressor
(AMG Sport pack)- NOW SOLD
Renault Sport Clio RS172
Ropey o
Morat
The cheapest option, and tell her the truth.
cecotto479
- Caution Unreliable Seller
1. Option one doesn’t need a new clutch ”“ that’s only a suggestion if you go for the second hand engine.
2. Labour so far is included in all options - and would be required in options 1 and 2 anyway, though quite why I'm explaining this to you in public, I have no idea.
1981 E23 735i
gooner1
- Out humping Reindeer
Honeymoon over before the Wedding.skipunda wrote:Bit of a shock to the fiancée, going from no e30 to one in bits and a breaker on the driveway!
snakebrain
Option 5 - buy a good used cylinder head from Andyboy and take the car somewhere reputable to have the work done.
Cloggy Saint
kieran325
Is this right ??snakebrain wrote:The plot thickens! So you reckon it's already had a swap?Andyboy wrote:It already has an E36 engine by the look of it, a post 9/93 motor.
snakebrain
Would imagine so if Andy says it is..
Might be a handy way to force the dealer to take it back?
cecotto479
It has the later bottom idler rail rather than the wheel. The rail is £10 rather than £100 for the wheel. It looks like earlier single valve springs rather than the later double ones though, but I’m not certain as once I took the head off I just left it ”“ I haven’t stripped it further.
Andy's E36 info is based on me telling him about the bottom idler rail as opposed to anything that he noticed looking at the photos of the car.
I'm sure the guide rail on the inlet side has broken down allowing the chain to go slack on the inlet side and bounce off the inlet cam sprocket. All 8 inlet valves are bent. All 8 exhaust appear fine.
The profile gasket looked very new.
On a positive note, the OP has had £350 (I think ?) back from the seller
Morat
That should cover the cost of.....
pac1982
Perhaps I’m just way out of touch with the cost of labour these days and the fact that me and my mate fitted my replacement engine for free in my 318is don’t help, so I apologize in advance if I’m treading on anyone’s toes here, But where are all these costs coming from, over a grand to throw another engine in a car that’s not even an engine conversion seems very high to me.
I got my replacement engine for £200 took me and my mate day to fit it job done.
Because it was the same engine we used the same mounts, no need to make a custom exhaust no messing around with wires just bosh the old one out and bosh the new one
I understand it costing you more than this if you have to pay someone to fit the engine but not over a grand!
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
Nasty mod !skipunda wrote:Bit of a shock to the fiancée, going from no e30 to a 5k breaker on the driveway!
cecotto479
pac1982 wrote:..........
So it took two of you a day?
What's a fair commercial rate for two day's labour then?
1981 E23 735i
snakebrain
How long should it take a professional mechanic who's not larking about with his mate might be a better question..cecotto479 wrote:So it took two of you a day?
cecotto479
Fair point. What's a fair commercial rate for one day's labour then? 8 hours @£30?
1981 E23 735i
bodger
its not two days commercial though is it, a 'professional' would do it in 1 day, theres a difference between doing an engine change in a workshop and doing it at home on a drivewaycecotto479 wrote:So it took two of you a day?
What's a fair coomercial rate for two day's labour then?
cecotto479
See above.
1981 E23 735i
318isPMK
Right u lot this isnt helping, I was asking for advice about clutch no clutch and what option you's would plump for Not for you to have a pop at my Mechanic if you have an agenda please take it elsewhere!
This may well be my fault for posting prices up here but it wasnt meant to used for this purpose simply to give an idea of cost when waying up each option!
318isPMK
bodger
was the clutch slipping? no point throwing money away if it was ok318isPMK wrote:Right u lot this isnt helping, I was asking for advice about clutch no clutch
