After making some tweakings to my M40 seems like the cylinder identification sensor has broken. Because the HT leads are reasonably well for their age, I got a second hand nº4 HT lead with the CID sensor.
I want to know if it's necessary to dissasemble anything to put out the old and put in the new cable and how to do it, because it goes in front of the timing belt cover to the diagnostic socket. I understand how to change the other 3 HT leads, it's pretty easy, but this one seems to be tricky.
Can this make the engine run smoother on cold? Because it seems to flood on cold, even one day I started it like 10 seconds to test a thing, and when next day I was going to start it it was like some sparkplug was flooded, it was running on 3 cylinder
Thanks!
