Top of Rear Shock
kam-325i
Post Fri Jan 20, 2012 8:06 pm
Quick question......
Is this the correct way to assemble top shock mount or is something missing
Click for larger image.
BenHar
Post Fri Jan 20, 2012 8:19 pm
Looks right. The plastic tube should be clipped over the big washer.
Ben
kam-325i
Post Fri Jan 20, 2012 8:21 pm
BenHar wrote:Looks right. The plastic tube should be clipped over the big washer.
Ben
Yeah, i took it out for clarity.
Post Fri Jan 20, 2012 10:07 pm
That's correct! The steel washer directly under the rubber mount is the one that often gets left out.
kam-325i
Post Fri Jan 20, 2012 10:19 pm
thats what i was worried about......
So if people leave the big washer out, what are they fitting the shock dust cover to ????
Post Fri Jan 20, 2012 10:41 pm
kam-325i wrote:thats what i was worried about......
Not all aftermarket dust cover incorporate the steel washer.
When a fitted the last set of B4s that I'd bought, the dampers that I removed were not OE, and had welded on steel dust covers.
I pulled a set of old OE Boge dampers out of the scrap pile and transferred the plastic dust covers, complete with the washers from them to the Billies.
