Post
Sat Nov 19, 2005 9:15 am
Lots of stuff on head gaskets on the forum here. Try doing a search.
I'd say a garage will charge from Ԛ£500-Ԛ£600 to do the job. You should always change the cambelt at the same time, which might add another Ԛ£100. But the garage would just do what you've asked, nothing more.
If you are mechanically able, it's much better to do it yourself.
The problem is, when you split the engine, you see lots of things which 'could do with being done'. (I replaced all the hoses hidden under the inlet manifold, even though they looked OK for another 5 years, on the grounds that the access is so difficult, you don't want to be under there too often)
So you'd probably spend more doing it yourself, but you'd have a much better car at the end of it. It's a fairly straightforward job, with no special tools needed other than a good socket set and a breaker bar. The first time, because of , nervousness, tight and corroded nuts etc, it might take about 15-20 hours. I feel confident I could do a gasket change in about 4 hours now though.
