Tom_Maverick wrote:
...and penniless coonts who think they should get something for nothing..
unless the item belongs to them in which case it's worth well over the odds..
sad, but true sometimes
For BMW or just in general ?Speedtouch wrote:I suppose that being a relatively early example of a 16-valve engine in a production car,
Engine wouldn't be to pricey at all. Could pick up one off here for around the £300 ish mark. Yes it's a gamble on how it runs, but m20's are simple. £100 or so for timing belt (m20's are belt) and water pump so you know it won't fail and away you go.318isPMK wrote:I dont know about changing engines and all that its sounds dear and means I'm buying an engine I dont know so could end up back in the mud again.... plus I'm 26 so insurance premiums on a modified car with a replacement engine will end me!
I would imagine
ross_jsy wrote:Engine wouldn't be to pricey at all. Could pick up one off here for around the £300 ish mark. Yes it's a gamble on how it runs, but m20's are simple. £100 or so for timing belt (m20's are belt) and water pump so you know it won't fail and away you go.318isPMK wrote:I dont know about changing engines and all that its sounds dear and means I'm buying an engine I dont know so could end up back in the mud again.... plus I'm 26 so insurance premiums on a modified car with a replacement engine will end me!
I would imagine
You have the advantage of having 51mm struts and rear discs being an iS. Only thing I'm unsure of is wiring, but it will be easy.
Can't possibly comment on insurance though.
Just food for thought
