No idle and missfire until 4000rpm
randomspeedfreak
Post Thu Jan 05, 2012 8:51 pm
Right the m52 is on the road :D :D :D
however, amongst other things to sort, the main problem is the idle and bottom end of the rev range!
it starts first time every time, and from cold idle is okay, however if i come to a junction when warm the car will stall
the car missfires under normal warm driving, it runs on less than 6 cylinders, then, consistantly as the revs rise and it hits 4000-4500rpm it clears up and starts pulling properly with no missfiring
if i help it to idle a bit with the throttle then it can just about manage a very slow lumpy idle on its own
i can smell that its lean but what do you boys think it is? ive properly blanked off the nipple bit on the swan neck from the icv. today i swapped the icv over for another and encountered the same behaviour.
i have a noisy injector could this be the culprit?
i have yet to renew the gaskets on the bottom of the m50 inlet as i was told they dont often fail. ill order some of these in if you boys think these could be at fault
how can i test the signal to the icv? (if the icv was half open id get this behaviour right?)
Post Thu Jan 05, 2012 9:14 pm
As long as the ICV moves it should be working fine. Shite running when warm is a common crank sensor issue
Post Thu Jan 05, 2012 9:17 pm
make sure the injector plugs /rail are pushed well down onto the injectors and that they make good contact
randomspeedfreak
Post Thu Jan 05, 2012 10:18 pm
[quote="DanThe"]As long as the ICV moves it should be working fine. Shite running when warm is a common crank sensor issue[/quote
my crank sensor is pretty dogey. ive got another one on order.
cheers dan
randomspeedfreak
Post Thu Jan 05, 2012 10:19 pm
E30BeemerLad wrote:make sure the injector plugs /rail are pushed well down onto the injectors and that they make good contact
ill check tomorrow morning, thankyou mate
randomspeedfreak
Post Tue Jan 17, 2012 7:50 pm
okay ive still got this problem. new crank sensor in. canged the icv over and it made no difference.
the car smells lean and runs better when it is running richer i.e. from cold
is my next port of call air leaks?
or could it be the e36 temperature sensor?
would a sticky injector do this? one of mine is making a hell of a racket
rich318i
Post Tue Jan 17, 2012 8:15 pm
randomspeedfreak wrote:okay ive still got this problem. new crank sensor in. canged the icv over and it made no difference.
mate get it on a computer and see what fault codes pop up
randomspeedfreak
Post Wed Jan 18, 2012 3:00 am
best way of doin this? ive never used a computer to diagnose before! how exciting! haha
randomspeedfreak
Post Wed Jan 18, 2012 9:00 pm
just think could it be a lambda sensor? ive noticed the car runs fine for the first few minutes after switching it off (i.e. before the lambdas have heated up possibly?)
how should i test them? what ohms should be across which pins when?
having about 20 thoughts a day about torching the thing atm
e301988325i
Post Wed Jan 18, 2012 9:12 pm
Unplug the lambdas and see how it runs the car will use a default value in this situation. quite difficult to test them, you need to test their 1v output by heating with a blow torch, do not measure their resistance. Lambdas with a corectly working heater element should be up and running in under a minute.
I said:
e30topless said:
lock the wife in there
randomspeedfreak
Post Thu Jan 19, 2012 12:25 pm
e301988325i wrote:Unplug the lambdas and see how it runs the car will use a default value in this situation. quite difficult to test them, you need to test their 1v output by heating with a blow torch, do not measure their resistance. Lambdas with a corectly working heater element should be up and running in under a minute.
okay thankyou bro. ill unplug them out and see how it runs then.
do you think i could be onto something? i mean from the symptoms described any ideas?
Post Thu Jan 19, 2012 12:30 pm
Have you got the lambdas plugged in correctly?
The lambda for the rear exhaust branch plugs into the connection on top of the engine nearest the front and the front exhaust branch plugs into the plug on top of the fuel rail nearest the rear of the engine. They run like cack if not correctly plugged in
randomspeedfreak
Post Thu Jan 19, 2012 1:21 pm
E30BeemerLad wrote:Have you got the lambdas plugged in correctly?
i thought they only plugged in one way around?! quite possible ill check when i next see the car - its currently stranded at my mates after the bottom rad hose split.
£18.50 +vat from the stealers for a bit of rubber!
e301988325i
Post Thu Jan 19, 2012 7:08 pm
Apologies for my spelling and grammar in that post, was in a rush.
I don't think lambdas, more likely: crank sensor, vanos, cam sensor?, one of the coil on plugs. I honestly can't think of a single instance of a faulty petrol injector. It's worth unplugging and swapping lambdas over for an easy test. They can be plugged in the wrong way around, which on Simons recent E36 24v thread caused odd things to happen.
I said:
Post Thu Jan 19, 2012 7:14 pm
Ive had sticky injectors before a couple of times, both times it was 2.8 injectors that id taken from scrapyard cars or engines id bought that had sat for ages.
For the £60 it costs its worth having the injectors serviced anyway IMO, injectortune on here do the £60 discount price for zoners.
Crank and cam sensors on these are known to cause intermittent running problems without giving fault codes, the only downside is the genuine sensors are £££ and the non genuine are very poor quality
rich318i
Post Thu Jan 19, 2012 8:18 pm
pay the money and never cut corners on cheap parts
randomspeedfreak
Post Sun Jan 22, 2012 10:12 pm
rich318i wrote:pay the money and never cut corners on cheap parts
at which point did i not pay the money and cut the corner? :?
okay lads thanks for your input. ive just replaced the hose and drank some coolant again so the cars back.
ive unplugged the lambdas and swapped them over and although initially i thought it made a difference it infact dosent really change much that i can tell. the transition between being missfiring and running clearly is now a lot more gradual i think? which is weird. they were however the wrong way around before.
so ive got pretty much the same symptoms, from the 5 minutes ive just driven the car the missfire is still there.
whats my next bet? im sending the injectors to injectortune, they dont do discount if it isnt an e30 engine. still they make a hell of a racket so £81 well spent imo.
anything else i should do? im pretty sick of this now to be honest!
Post Sun Jan 22, 2012 10:26 pm
Ive sent M52 injectors to them before and theres not been a problem :?
Did you tell them your an E30 zone member hence the reason your contacting them?
Have you tried a different MAF yet? Or tried with the MAF unplugged?
randomspeedfreak
Post Tue Jan 24, 2012 7:55 pm
DanThe wrote:Ive sent M52 injectors to them before and theres not been a problem :?
hes saying hes never offered a discount to zone members with non oem motors?
anyway ill send them off as soon as im paid
the car has been a little better with the lambdas the right way around.
with the maf removed the idle is a little better, but it is a little worse elsewhere in the rev range.
will a m52 7 series airbox fit the e30? there is a genuine maf with this box on ebay i could do with a proper box i have a pikey cone on atm
cheers,
matt
randomspeedfreak
Post Thu Jan 26, 2012 7:39 pm
if anyone can help me out with this it would be great. im really down about this now. the car is now consistantly missfiring below 3k. above it is usually alright, but occasionally it will throw a spanner in the works and missfire all the way up the rev range?
what the hell is going on?!
injectors are going off next week.
could it be the air temp sensor?
still no idling apart from when cold
e301988325i
Post Thu Jan 26, 2012 7:58 pm
have you at any point had your fault codes read by a garage or tech friend? You say you have an M50 manifold on an M52, is that actually the case, if so did you get it remapped?
I said:
randomspeedfreak
Post Thu Jan 26, 2012 9:14 pm
e301988325i wrote:have you at any point had your fault codes read by a garage or tech friend? You say you have an M50 manifold on an M52, is that actually the case, if so did you get it remapped?
i havent had them read no, yes its an m50 mani, and no it hasnt been mapped.
should i order one of these then?
http://www.ebay.co.uk/itm/BMW-E36-3-Ser ... 2131wt_932
*edit it says e36 in the title but not the description whats that about? will it work? what does everyone use?
Post Thu Jan 26, 2012 11:12 pm
You could try it, probably a rip off of carsoft. Its worth trying a different MAF IMO
randomspeedfreak
Post Fri Jan 27, 2012 11:58 am
DanThe wrote:You could try it, probably a rip off of carsoft. Its worth trying a different MAF IMO
ok maf first with injectors then get the software out after that.
would it be worth getting a video up?
just noticed slight possible vanos rattle at 2k on part throtte :(
Supafly
Post Fri Jan 27, 2012 2:59 pm
have you taken the coils out and checked inside plus checked the plugs?
during my engine swap water somehow managed to get into the sparkplug area in 5 & 6 which caused a misfire
randomspeedfreak
Post Sat Jan 28, 2012 3:42 pm
Supafly wrote:have you taken the coils out and checked inside plus checked the plugs?
i havent since i put the engine in, plugs were changed when i did im going to my garage now ill ahve a look. its not a consistant missfire. although it has got worse again now!
cant wait for payday to get this sorted!
randomspeedfreak
Post Fri Feb 10, 2012 5:04 pm
been running better recently. much less missfiring but its still cutting out
put another maf in there just now.
no change at all its the same.
im plannig on torching it?
randomspeedfreak
Post Fri Feb 10, 2012 5:07 pm
just realised - should i have a temp sensor at the airbox end?
randomspeedfreak
Post Sat Feb 18, 2012 7:54 pm
right i sort of solved this one.... there was a leak between the throttle body and the manifold...
secondly i hadnt blanked off the vacum inlet on the botttom of the throttle body...
and finally i had a leak between the vacum for the fuel pressure regulator, and the manifold
im still getting a lumpy idle at around 600 - 1000rpm, and i still get an occasional missfire below 4000rpm.
i have no idea what this could be as ive checked and re checked for leaks
any thoughts?
