New key - single fob
cee
I currently have a separate key and fob, which is fairly irritating and chunky in my pocket, and rattles when driving. Is it possible to set up a more modern style key with the remote locking electronics in the key?
1990 Sterlingsilber 318iS - 146 bhp / 192 Nm
cee
So replacing the entire system would be the easiest option?
cee
& is getting a kit like this not risky due to the coding used - may not be unique etc.
depends what system you have.cee wrote:& is getting a kit like this not risky due to the coding used - may not be unique etc.
millions of different codes plenty of zoners have used similar kits, there used to be one with e46 keys however ive not seen any for ages
cee
So how does it work, because currently I have a single button fob, that when pressed unlocks the car and disables the alarm and immobilizer, and vica versa when pressed again.
Would a new system like this be compatible with my current alarm/immobilizer set up?
