Hello fitted an mtec steering wheel at the weekend getting a slight squeek around 270 degree's.
The washer was rusty but I didnt think anything of it do you think thats the cause? or have i fitted the nut too tight or maybe something should have been greased its not been on the car for a good while.
Paul
Squeeking Steering Wheel, Help needed Im clueless!
bmw_325i
Possibly the carbon contact for the horn is making some noise against the slip ring on the back of the steering wheel?
Copper anti-sieze paste is the go to lubricate the slip ring.
Rtaylor2208
There is also a bearing inside the ignition pipe metal thing (no idea the proper name for it). This can have a small hole drilled in it and lubed up with the white greese, this usually fixes the problem from what I have read. Its also on my to do list.
318isPMK
It didnt squeek with the aftermarket one so I assume it has to do with the rusty washer.
