I'm only used to driving newer cars so a bit worried about pranging my baby
318 iS Idea's how to improve brake performance
318isPMK
My 318iS Already has good discs and pads but looking for more info on what to do to improve braking performance so its more like a modern car.
Grrrmachine
- E30 Zone Wiki / Team Member
Go to the gym and build up your leg muscles! The brakes on an iS are fine.
Still, it's worth reading these two articles:
http://www.e30zone.net/e30zonewiki/index.php/Brakes
http://www.e30zone.net/e30zonewiki/inde ... e_Upgrades
The brakes are as good as any modern car, if they're working as intended, or are you confusing brake pedal pressure with braking efficiency?
The pedal pressure required is a function of servo/cylinder size and ratios, and could have been set at any level the designers at BMW chose. A similar thing applies to the steering rack ratio.
These would have been set to the preferences of what market research said was the most acceptable at the time the E30 was designed, so neither should be considered a fault; just a consequence of changing tastes and the 'feminisation' of car design.
