Eccentric Bushes? Which to buy SuperPro / PowerFlex / OEM M3
Jibberingloon
Thu Jan 12, 2012 12:08 pm
Also what is the M3 Part Number?
MrBenn
Thu Jan 12, 2012 12:31 pm
rossmc88
Thu Jan 12, 2012 12:52 pm
I bought some from cotswolds bmw off here in decemeber, cost £46 delivered
Thu Jan 12, 2012 1:50 pm
Note that this part number gets you two bushes - you only need to order one.
Jibberingloon
Thu Jan 12, 2012 1:52 pm
The OEM item is more than a Poly Bush......!!
So would you all still go for OEM over Poly?
rossmc88
Thu Jan 12, 2012 1:54 pm
yep
Thu Jan 12, 2012 2:04 pm
Every time! Works better and probably lasts longer.
Kos
Thu Jan 12, 2012 2:10 pm
The powerflex ones have been known to fail due to their shitty 2 peice design
This failure has happened when driving, id always used OEM or treehouse racing ones.
www.pukardesigns.com
IG Pukar.Designs
alan1272
Thu Jan 12, 2012 3:50 pm
Kos wrote:The powerflex ones have been known to fail due to their shitty 2 peice design
i've heard of the concentric (one piece) bushes failing (pushing out of the lolipop) but never the eccentric ones. i've run them myself on the rally car for 4 years and have never had any issues.
HairyScreech
Fri Jan 13, 2012 12:55 am
Oem all the way on this one, for twenty quid you get a pair of fit and forget bushes.
