brown temp sensor
RichIS
Post Thu Jan 12, 2012 4:46 pm
what color wires should be attached to the brown sensor as looked at mine due to no temp on gauge and only one wire was attatched ive earthed the other wire still nothing .
then bridged the 2 pins together and temp goes round to red so unsure if this is wiring or just a dodgy temp sensor?
Injections nice....but I'd rather be blown ;)
Jimbob
Post Thu Jan 12, 2012 5:09 pm
It should be a brown / violet wire taken from the E36 sensor which is to the left of where you have the E30 brown sensor.
deanocool
Post Thu Jan 12, 2012 11:21 pm
do you defo have the right sensor in? what caught me out is the E30 brown temp sensor has the space for 2 pins but only have one pin in it set to one side. the sensor earths itself off the block rather than down the (imaginary) 2nd wire, thats why theres only one pin. :)
check this out....
intermotor part number is 52101, that what i ordered at work and its aok!
