325is engine with a mind of its own!
Unitt
Startin running on 5 cylinders the other day so i pulled ht leads off 1 by 1 to see which 1 was missing and it now runs on all six but ticks over at 2500rpm dont think its the connector for injection wiring as its already been cut out and wires soldered together. any ideas?
Rtaylor2208
Possibly the idle control valve remove it from the the air box and throtlle body and clean through with Carb cleaner. Also check for air leaks by inspecting all air intake hoses for cracks and loose fitings as a starting point.
