I am so sad that I have to make my first post with my problem. I came on this forum as recommendation from one user at bmwe21 forum. I think also that I can find some help here because my problem is related to BMW E30 L-Jetronic system.
Recently I had an upgrade with my M10 2.0 engine from solex 32/32 to L-Jetronic system. The complete system was taken from E30 87 or 88 (I am not sure but I think that it's 88) Manifold, engine installation, fuel rail, injectors, air mass sensor etc...whole system for this setup. I have upgraded everything and also finished everything with electric but it just want fire up! All indicators on dashboard are working, I have sparks on spark plugs (I have checked). But... - I don't have any fuel - pump is working for 2 sec after I turn the key on contact (I am rechecking fuel pressure tomorrow again ), I have noticed that ECU isn't activating injectors and cold start injectors. I have check all of these injectors and everything is working correctly. I have tried almost everything but it just want fire up. I presume that the problem is with some installation but I think that I have connected everything correctly. Also, I have tried to replace ignition module witch is siemens/Telefunken and still I don't have engine start. The ECU is 0280000328. At the end I thought that the problem is with ECU and maybe with transistor for driving injectors (OM323) but I can't check it because it's Darlington NPN with resistors and diode inside. Tried to google it - to find somebody who did this conversion but I didn't found anything, just found some pictures. Probably the problem is in front of me but I just can't see it. So...at the end the problem is with injectors (fuel) - the ECU isn't opening them and from that reason engine can't start up
All of these parts for upgrade I got from my friends card, I took it direct from the car except ECU witch was inside of his workshop. ECU was inside in the box with a lot of other ECUs but my friend told me that this is correct one (it was only that one from L-jectronic). Also checked in Bosch ESI and the number give me - E30 316/318i LEjectronic/Motronic from 84-88. In the meanwhile I found from another friend the another ECU which is 0280000330 and Bosch ESI is also giving the same results except it's only giving 318i from 84-88 Lejectronic/Motronic. I tried to fire up with this one but still nothing
Also tried to find electrical wiring diagram for this L-jectronic 88' but I can't find it at all. There is everything except this one
So far - 8 days passed and I still can't get it resolved. If somebody knows something regarding this issue please write here, or maybe if somebody knows for some link with this kind of conversion, please post it here. Thanks a lot!
p.s. I will try tomorrow to measure fuel pressure again, maybe it's not enough to open injectors but I think that I have correct pressure. When I try to fire up I can't hear sound of injectors that they are opening (it's noisy but there is no tak tak tak sound
