2.5 and 2.0 air flow meters
johnono
sounds stupid but is the 2,5 afm a possible replacement part on a 2.0
E30Adam
Not really. If you mean as an upgrade, this was tried with an M30 AFM on a 325 and it lost me 11bhp on the rollers.
I'd say stick to the stock one unless you're going MAF or MBE
2.8 Litre M20 powered - Essen Sie meinen Staub biatch
johnono
ok, cheers ad
but do they line up , as in inlets and so on are the same size or not?
Davenotouring
They do line up mate yes.
I've got a 2.5 one on mine at present.
Not as in a power increasing mod, but because I was trying to solve a running problem. Runs ok with it on, but I suspect it's causing over/under fuelling.
BMW 328i Cab - Daily Slag
johnono
do u get the flat spot still with the 2.5 afm
Davenotouring
Yes mate.
Around 4.5 to 5.5k rpm.
In that area.
A chip should solve this.
Speak to ANT!
In that area.
Speak to ANT!
johnono
o, mines fine up there
i just get the hessitation with a quick jab of the accel.pedal when im at idle
what dyo reckon it is?
and im sure weve had this chat before
Davenotouring
Oh right, I used to have that. After playing around with loads of bits, it's much much better now.
I am currently running a 2.5 AFM, but changing to a borrowed 2.0 made NO difference in running.
I also tried numerous ICV's and none were any better than the other.
I am currently running a 2.5 ECU. This has stopped the momentary flat spot when you go to pull away at a junction etc.
I can only assume the old ECU was faulty, or something cured itself.
johnono
aha, would a 2,5 chip be a bad idea with a 2.0 afm
Davenotouring
A 2.5 chip would be pointless really.
I would go back to fully operational 2.0 stuff if I could, that's if I was staying 2.0, and if I was, I'd get a zone chip. But I'm going 2.5 so this will suffice for now! It runs!
Go for a 2.0 Zone chip I reckon.
johnono
sweet dave, ive got ants email, as soon as i am on it ill get sorted
Ant
- Retired Team Member
ahh, the stumble just off idle is normally down to a shagged/dirty TPS dude, either that or your throttle cable is poorly ajusted.
check the operation of the TPS before spending out £Â£ M8
johnono
ant, there is abit of slack on my acc. cable, but the pedal feels fairly responsive, can i adjust it myself
idle normal after warmup 6-7
before warmup 10
before warmup 10
Ant
yeah just tweak it til the slacks all gone, then check it goes full open/closed when operated via th pedal, get loads in @ work that only give 3/4 off WOT with slack cables dude
TPS stil needs checking though M8, the cold start idle is down to a coolant temp sensor signal to the ECU
johnono
sweet ant
give it a shot on the cable slack, changed the blue and brown when i first got her but needs a set of filters and a spark change
Demlotcrew
good thing about the M42 is that it has auto learning TPS.
