Sorry if this is already here somewhere, Ive tried searching for it, just finished the conversion and Ive used the wrong one(its blue instead of brown)
Has anyone got a part number for the brown temp sensor for an m52b28?
brown temp sensor part no.?
For the brown sensor, you use a M20 one otherwise your gauge won't read right
Green
12621710512 brown temp sensor for a m20
Jimbob
That part number is also listed for the 4 cyl engines, I think Beemerlad is getting confused with the coding plug.
joshce
Nice one lads, appreciate that!
No mate, you need M20 brown sensor or your temp gauge won't read correct.Jimbob wrote:That part number is also listed for the 4 cyl engines, I think Beemerlad is getting confused with the coding plug.
The coding plug is for the tacho
Jimbob
So there are differences between the M40/M42/M20 brown sensors even though they're the same part number? Damn...was hoping to save some cash and pinch the one off the M42!
The brown E30 single pin sensors are all the same
All the same, and rarely fail. Any second hand one will be fine.
Jimbob
Another thing, mine also screwed straight in - didn't need turning down.
joshce
Might have a look in the scrappers so, cheers
deanocool
