e46 shock top mounts + cup
ali50ferrari
Post Tue Jan 10, 2012 11:23 pm
so my cab (1989 325i e30 prefacelift) is currently runnin 60mm all over im lookin to raise up the rear to 40mm leave the front 60mm, while i do the rear shocks and springs i want to do the shock top mounts aswell as i want to upgrade mine, so my question is. . . . .
what e46 topmounts will fit mine,
what else is required to fit them,
is it straight forward or do i modify?
what is this cup thing i need aswell?
all info appreciated
The preacher is pious lord, for he is scared of hell, where as me I sinned freely trusting in your mercy
Post Wed Jan 11, 2012 12:08 am
E46 cabriolet mounts. They are identical in appearance and dimensions to the E30 ones, but have an important hidden difference.
Nothing else is required to fit them; they are a direct replacement.
ali50ferrari
Post Wed Jan 11, 2012 12:25 am
hidden difference?? realy whats that then? i thought some sort of cup was required otherwise they split? arent they thicker or longer lasting etc, why is it a better upgrade?
Post Wed Jan 11, 2012 8:47 am
The centre steel bush in an E30 mount is a simple plain piece of steel tube. The equivalent piece in the E46 mount is allegedly barrel shaped, so is less likely to detach from the rubber.
Cup: You could be referring to two things here. 1) There needs to be a large steel washer on the damper rod both above and below the mount, to spread the damping load into the rubber. On the OE Boge dampers the lower washer is part of the dust cover, and, when fitting aftermarket dampers, the uninitiated have been known to throw this washer away with the old units, leaving the whole damping load to be transmitted directly into the steel bush of the mount only. Not surprisingly, the mount will have a life of about two weeks maximum.
2) The Z3 uses a reinforcing plate to strengthen the part of the bodyshell that the mount fastens to. These will fit an E30, but, on an E30, are a solution to a problem that doesn't exist.
ali50ferrari
Post Wed Jan 11, 2012 11:05 am
Brianmoooorezone.net, your a fookin legend, anyone know the part numbers for the 2 parts? and which e46 cab mounts should i use?
Ajsingh
Post Wed Jan 11, 2012 8:28 pm
E46 M3 cab ones are used. Go for them
E30 Crazy!
Post Wed Jan 11, 2012 10:49 pm
Ajsingh wrote:E46 M3 cab ones are used. Go for them
Part # is 33 52 6 779 670. Nothing 'M3' specific about them. The same part is used on all E46 cabs, from the lowliest 318 right up to the M3.
ali50ferrari
Post Wed Jan 11, 2012 11:16 pm
And the cup from the z3 wat is the part no for that?
ali50ferrari
Post Sat Jan 14, 2012 12:16 am
Anyone know the "cup" part number?
Gumdrop
Post Sat Jan 14, 2012 9:52 am
Hey!
Can I ask a question about fitting E46 top mounts please?!
Yesterday I replaced my worn out original E30 top mounts with the E46 ones. When I had finished, I looked into the boot at the top mounts, bounced the car on the spot and still had play in them. The damper rod seems to protrude into the bootspace by a centimetre or so when I applied my weight to bounce the car. I have held the damper rod so it wouldn't spin and tightened the 17mm nut down as much as possible but it's still playing! I puut everything back in the way it came out, I can't understand it! Is there something else needed to run the E46 mounts that I have possibly left out?
Any help with this is greatly apprieciated!
Thanks!
BenHar
Post Sat Jan 14, 2012 3:30 pm
