Head lamp wipers/washers
kurtG
Post Sun Jan 08, 2012 11:21 pm
They don't work on my car or atleast I think they don't I'm not quite sure how to make them work?! Should they just work with the screen wash when you pull it back or it's it when you push it in? Iv checked some fuses but I'm not sure which one is for the head lamp wipers? Is there a common problem with them??
Any help apricitated cheers.
Sanchez
Post Sun Jan 08, 2012 11:23 pm
Quite often the motors fail.
Plenty spares on ebay if you search for them.
Jim320i
E30 Zone News / COTM Team
Post Sun Jan 08, 2012 11:27 pm
First thing to do would be test the motors are working... Take them off and supply power to them independantly, if they start moving then you know the fault lies elsewhere, if nothing happens, try opening them up and easing the up a little as they may just be seized! Which to my knowledge is the most common fault for them not working!
kurtG
Post Sun Jan 08, 2012 11:32 pm
Right so check the motors, but I'm not getting a power feed to the washer pump when I press the lever or pull it. Is it fused? Want to get these working quite a nice retro feature.
chh137
Post Sun Jan 08, 2012 11:35 pm
have you got head lamps switched on ?
kurtG
Post Sun Jan 08, 2012 11:40 pm
Yea I do. Do you push or pull the stalk to make them work?
chh137
Post Sun Jan 08, 2012 11:42 pm
ign on head lights on then wash /wipe windows and h/lamp ststem should operate.
kurtG
Post Sun Jan 08, 2012 11:44 pm
Right now iv got some stuff to go at. Do you kno which fuse they are on?
leeparkes
Post Sun Jan 08, 2012 11:46 pm
Im sure they operate after about 5 squirts of the windsceen washers with the ignition and headlights on.
chh137
Post Sun Jan 08, 2012 11:50 pm
fuse no 5. 30 amp . relay K10 I think.
Post Sun Jan 08, 2012 11:54 pm
Headlamp wash/wipe should operate every fifth time the normal screen washers are used when the lights are on. Doing this in quick succession doesn't work.
The most common fault with them is that the output shafts seize in the threaded bushes that mount the motors, as mentioned further up the thread.
The seized up motors are protected against damage by a disc shaped PTC resistor inside the gearbox housing, so in most cases they can be dismantled, treated to new grease and a new rubber seal on the end of the output shaft, and will be good for another fifteen years or so. The only one I haven't been able to rebuild was one where sufficient water had got inside to completely rust through the motor casing.
The control box (mounted on the washer bottles) is just to start the wipers off after tye five screen washes with the lights on. Once started, the wipers control themselves for the complete wipe sequence, and one of the motors controls the headlamp washer pump.
Post Sun Jan 08, 2012 11:56 pm
kurtG wrote:Right now iv got some stuff to go at. Do you kno which fuse they are on?
Same fuse as the normal screen washers and wipers, so won't be a fuse problem.
SGP
Post Mon Jan 09, 2012 12:04 am
Seized output shafts. As usual.
If it ain't broke..
Fix it till it is :)
suedenim
Post Mon Jan 09, 2012 1:00 am
1982 E21 316 Baltic Blau
1989 318i 2 Door Sterling Silber
Feedback: http://www.e30zone.net/modules.php?name ... highlight=
kurtG
Post Mon Jan 09, 2012 8:23 am
Some good help here cheers I'm going I get the motors off on my lunch an have a looks..
kurtG
Post Mon Jan 09, 2012 10:22 pm
Took motors off on my lunch. Both are perfect, like brand new in sidevthem. Spindle doesn't have any rust at all and both small rubber boots intact. So that eliminates them... The windscreen washers work perfect so that eliminates the fuse. Iv worked the screen wash in excess on 20 times with dipped beam on and still nothing.. There is no power going to the head lamp washer bottle pump. These need to work for new mot guide lines as well..
Jim320i
Post Mon Jan 09, 2012 10:23 pm
Did you test the motors independantly? I recently openned a set up, both mint on the inside but one wouldnt budge...
kurtG
Post Mon Jan 09, 2012 10:36 pm
Will do that tomorrow morning. My power probe was at home in my pick up.. I noticed that the drivers side one had 4 wires is that just a bridge to the other side motor?!
Post Mon Jan 09, 2012 10:42 pm
Brianmoooore wrote: one of the motors controls the headlamp washer pump.
Post Mon Jan 09, 2012 10:53 pm
Get them off the car and onto ebay mate, £275 + now :)
Jim320i
Post Mon Jan 09, 2012 11:07 pm
DanThe wrote:Get them off the car and onto ebay mate, £275 + now :)
£275 was mine the other day :cool:
Post Mon Jan 09, 2012 11:14 pm
Record? :D
threelander
Post Mon Jan 09, 2012 11:23 pm
well advertised i wouls say.usually they go for around £95 to £140
Duke137
Post Mon Jan 09, 2012 11:25 pm
Jim you sold the headlights and grills too remember. Where did you post them too? Thailand, USA, Aus...?
Be surprised if they stayed in th UK
threelander
Post Mon Jan 09, 2012 11:26 pm
exactly duke
Jim320i
Post Mon Jan 09, 2012 11:46 pm
True... I sold them with everything, but only because I would have been left with headlights that had a crack in one and no rings... And the surrounds are 10 a penny... And off to Malaysia I think from memory.
SGP
Post Tue Jan 10, 2012 1:56 am
Shouldn't there be a separate wash fluid tank with a pump for the "intensive" headlamp wash cycle ?
If it ain't broke..
threelander
Post Tue Jan 10, 2012 4:00 am
no steven it,s a double bottle for cars with hlww mate
Post Tue Jan 10, 2012 8:55 am
Head lamp wash wipe needs the double tank, but the headlamp wash fluid comes from the large tank, the same as does the fluid for the normal screenwash. There's no place to fit the second pump on the standard single tank.
The small tank is filled with a (very effective) special fluid from BMW, for the intensive screen wash function.
suedenim
Post Tue Jan 10, 2012 9:11 am
threelander wrote:well advertised i wouls say.usually they go for around £95 to £140
I agree, very well advertised, better than most selling whole cars!
I'm about to removed a set and it has served as inspiration for me restore and ensure they are working 100%.
Well done Jim!
kurtG
Post Tue Jan 10, 2012 9:08 pm
Right spent a bit more time on this at lunch. Powered up both motors and they both work perfect... Then I was tracing wiring back and saw another motor hidden next to the wing on the big bottle.. As Brianmooore said the big bottle does both windscreen and head lamps.. This motor wasn't plugged in. So plugged it in and jobs a gooden they work....... But...... They seem to move 10mm after every time I use the wipers. They don't park correct either.. The relay inbetween the washer bottles is buzzing. Are these known of going faulty??
kurtG
Post Tue Jan 10, 2012 9:16 pm
These are the number off the relay I think is possibly faulty..
Post Tue Jan 10, 2012 9:46 pm
The control modules are normally reliable, as long as they are mounted where they should be, on the washer bottle. The mounting on the bottle is fairly fragile, so if it is broken, and the module is lying on the chassis rail, they can be messed up if water gets into them. Water in it or not, yours seems to be faulty.
This module is one of the items that I don't have a circuit diagram for yet, although I'm working on it. I have one opened up and just need another hour or two of spare time to trace the full circuit.
kurtG
Post Tue Jan 10, 2012 10:22 pm
The tab that the module screws onto is broken yes and was loose.. Is that what controls the parking an regulates howe many times they wipe for? Bet they are expensive arent they?
Post Tue Jan 10, 2012 11:59 pm
The module just provides a short pulse to start the wiper motors. Once running, they control their wiping sequence and parking themselves, courtesy of a cam and microswitch inside the gearbox.
The wiper motor with four wires also contains a switch which works the washer pump.
The wiper motors have an ignition (first switch position) live to them, which powers the motors after the initial starting pulse from the control module.
What, exactly is the parking problem? Do the wipers park in the middle of a stroke?
