sunroof stopping before it fully closes
M42
Post Sun Jan 08, 2012 9:03 pm
my sunroof always stops a few times when closing or opening, just re-pressing the button always works but why does it do this? could it be the relay near the sunroof motor?
SGP
Post Tue Jan 10, 2012 1:51 am
Have you tried cleaning up the tracks ? Sometimes a little WD40 or similar, followed by a light grease can get things running smoothly again.
If it ain't broke..
Fix it till it is :)
Post Tue Jan 10, 2012 7:42 am
Its gone out of sync.
After you have lubricated the cables & mechanism you need to put the roof in its tilt position and then drop the motor down - its marked on the cog what position is what.
The best way to lubricate the cables without actually removing them is to undo and lift the stainless steel plates, wipe away as much of the old grease as you possibly can, and then re-lubricate.
If this doesnt work the cables need to come out.
I've re-done mine recently and it still goes out of sync quickly so I'm just going to live with it for now :(
Post Tue Jan 10, 2012 9:31 am
If the motor's gone out of sync on its own, then the damage has already been done - the re grease should have been done two years ago! The drive cog will have been damaged.
Re reading the OP, I'm not convinced it is out of sync, though. I think the motor might just be stalling because of thick cold grease.
Are you aware of the manual over ride provisions for working the roof?
M42
Post Wed Jan 11, 2012 12:39 am
i know you can operate it manually but dont know how to. so nothing to do with the relay then? might just need a lot of lubrication?
Post Wed Jan 11, 2012 7:09 am
When you're looking at the motor there is a large nut which needs to be loosened to disconnect the drive from the motor - you then use an allen key on the centre section to wind the roof open or closed. Once you have moved the roof manually to where you want it you re-tighten the nut to re-engage the motor.
Re-lubrication is definately the first thing you should be doing.
Post Wed Jan 11, 2012 8:50 am
capri_rob wrote:When you're looking at the motor there is a large nut which needs to be loosened to disconnect the drive from the motor - you then use an allen key on the centre section to wind the roof open or closed. Once you have moved the roof manually to where you want it you re-tighten the nut to re-engage the motor.
Note that this doesn't affect the synchronisation of the motor. This can only be done by unscrewing the motor mounting bolts, moving the motor to match wherever the roof is, then refitting the motor.
M42
Post Thu Jan 12, 2012 10:47 pm
cheers for the reply guys! :D
