Brake lights not working
lista
Checked and have live in and out of switch at brake pedal but brake lights not working.Looked in Haynes manual and there is a bulb control unit.Where is this fitted as it might be the problem.
Bulb check module is behind the LH boot liner, very close to the aerial, but is very unlikely to be your problem, unless one of its plugs has managed to partly detach itself in such a way that it interrupts both of the brake light signals and none of the others.
Pull the plug off of the brake light switch and use a piece of wire to link together both buckets of the plug, with the ignition on.
lista
Thanks for that,works fine when plug linked out so looks like switch
I suspect you have been doing your testing with a volt meter. Unless you fully understand their limitations, and how they often can give misleading results, a far better tool is a 5W 12 volt bulb attached to a couple of pieces of wire.
