My clutch master cylinder is leaking where the plastic elbow pushes into it.
I have removed the elbow, checked for damage and refitted it, but as soon as the resevoir is topped up, it starts to dribble out.
Should there be any sealant on this joint or do i need to change the master cylinder to fix this?
Clutch master cylinder probs
78gizmo
BadDave
Just change the master, and while you're at it,change the slave at the same time.
If one has failed,then it probably won't be long before the other one needs to be replaced as well.
You could invest 50p in a new plastic elbow. There shouldn't be any sealant or anything else - the elbow must be damaged.
