found this little device in the airbox of the e34 m50 i picked up for my e30
part number bmw1730682
realoem tells me its a thermostat of some sort
but what does it do? im not running an airbox so can i just join the 2 water hoses together? or should i leave it connected in the engine bay?
thanks
m50 airbox thermostat, what does it do?
bimanut
You dont need it.One of the hoses needs blanking off at the other end in the head, an old sensor or i think a sump plug fits also.Or weld up the stub thats already there. the other hose i think you can just leave off.
this is how you have it
be11
is this a thermostat that stops throttle body icing in cold weather?
yes
