m52 wireing help..
VW-will
Post Sat Jan 07, 2012 3:08 am
hi guys, done 90% of my wireing this evening alot easier than i 1st thought it'd be!:D ive got all the plugs connected, and have 3 pin for the icv left, 2pin for the air intake left and 3pin for the TPS, i also have a really long 2pin wire cant see where this would go? not sure if it'd be something toodo with the aircon or something?
BATTS91
Post Sat Jan 07, 2012 3:19 am
theres a 2 pin i think that should be with the 4pin round connector for lambda which is not used ! , the rest of what uve said here i cant make sense of hows it all goin seemin as u dnt txt bk you bore lol
VW-will
Post Sat Jan 07, 2012 3:34 am
i cant txt, as ive spent all my money haha! in broke atm, hence doing wiering myself... i have a 2really long 2pin that goes down near the PAS pump but its sooo long i know where everything else goes, just not this..
BATTS91
Post Sat Jan 07, 2012 3:50 am
heck mate ill give you bell tomoz , got a steering wheel now gna fit bush fillers and new pas pump when i cba , errr this wire its just a 2 pin on its tod ? i cnt memba how may pins everythin has on mine but i can imagine it could be for oil level sensor maybe ?
penton08
Post Sat Jan 07, 2012 7:41 am
It sounds like the reverse light wire mate, Not needed!
VW-will
Post Sat Jan 07, 2012 10:39 am
spot on penton....i remember now :)
BATTS91
Post Sat Jan 07, 2012 3:29 pm
hmm m50 doesnt have that , well mine aint so never would have thought that , why would it have that anyway its taken into the cars loom ?
Post Sat Jan 07, 2012 4:23 pm
Going from memory on M52 you have:
TPS - 3 pin
ICV - 3 pin
Inlet temp sensor (underside of manifold) 2 pin
Coolant sensor - 2 pin
Coolant sensor (brown sensor) 2 pin
Oil pressure sensor - 2 pin - back of oil filter housing
MAF sensor - round plug
VW-will
Post Sat Jan 07, 2012 6:59 pm
The reverse light switch is on engine loom on m52' totally forgot.. Don't have reverse lights anyway lol
