worn camshaft?
erst_ray
Post Fri Jan 06, 2012 2:19 pm
Hi guys. I have a 316I Lux that won't rev over 5750 rpm M40b16. Cam is not noisy at all. Could there be anything else causing it? Thanks Ray
Post Fri Jan 06, 2012 3:04 pm
5800 rpm is the maximum permissible for the 316i.
Are you trying to kill it ? :cry:
redcar
Post Fri Jan 06, 2012 3:43 pm
my one did this..didnt rev past 5500
balilu91
Post Fri Jan 06, 2012 3:47 pm
capri_rob wrote:5800 rpm is the maximum permissible for the 316i.
are you sure? i believe my m40 used to rev up to 6500 before it hit the rev limiter
erst_ray
Post Fri Jan 06, 2012 3:49 pm
Ha ha. Yeah something like that. I have increased the rev limit to 6.5k will hit the limiter if revving in neutral but not when driving. Is the afm a possibility?
chh137
Post Fri Jan 06, 2012 4:02 pm
Arrange transplant/death imminent :roll:
erst_ray
Post Fri Jan 06, 2012 4:06 pm
chh137 wrote:Arrange transplant/death imminent :roll:
Why do you think that? I don't drive the car hard but I am prepping it for the nurburg and want it right.
redcar
Post Fri Jan 06, 2012 4:13 pm
Believe me, its gone....
I purhcased my car off a chap who probably drove it really slow as it was an OEM car mine was....then i got it and was full throttle everywhere....A few few weeks went by, it got more tappety, wouldnt rev past 5500rpm ocassionally...It revs when you are in neutral but under load it wont go past 5500. Then when you accidentally hit 5500rpm and change gear, it hesitates for about 5 seconds...
Does that sound like what yours does?
chh137
Exceeding max permitted rpm=driving hard = death
redcar
Post Fri Jan 06, 2012 4:16 pm
Try new distributor cap and rotor arm
Probably worn cams though
erst_ray
Post Fri Jan 06, 2012 4:50 pm
Thanks I'll give that a try. Just hoping I didn't have to replace the cam but its sounding like I will. same symptoms but clears after about a second after changing gear. Thanks all
redcar
Post Fri Jan 06, 2012 5:02 pm
erst_ray wrote:Thanks I'll give that a try. Just hoping I didn't have to replace the cam but its sounding like I will. same symptoms but clears after about a second after changing gear. Thanks all
Lol exact same thing as with mine
You hit 5500, change gear...press full throttle and it just like burbles for a few seconds then starts shifting (100bhp?) again.
Are you sure you want to mess around with a 316i m40 engine? By the time you have replaced the cam and oil feeds etc. you may as well have just purchased a good running engine for the same price, whether it be an m40 1.6 or 1.8, or even the m42 1.8, which would be the best upgrade which is fairly easy to do.
Either way i see it, its gonna be £100+ to fix that engine, or £100+ and a bit of time to drop a new engine in there.
Good luck though, I hate the m40.
redcar
Post Fri Jan 06, 2012 5:03 pm
See my old thread and what was advised.
http://www.e30zone.net/modules.php?name ... t=camshaft
BTW, m42 will do double the mpg of your 316i
redcar
Post Fri Jan 06, 2012 5:26 pm
As someone else describes it:
"It seems the M40 is prone to camshaft failure, either because of inadequate oils supply or possibly the surface hardening of the camshaft or valve train components.
The symptoms of a worn cam is that the engines wont rev over 5 to 5,5k and misfires the first second or so after a gearshift during wide open throttle accelration. It can also be intermittent, the engine can occasionally rev normally to redline but most often not. Wear can ususally be spotted by inspecting the camshaft, but to inspect the rocker arms and pressure discs the camshaft has to be removed from the engine."
Thats exactly what mine did and as though yours sounds like it is doing.
erst_ray
I have thought about a transplant but m42s are quite had to come by and any m40 i buy will probably need head work anyway. Anyone got an m42 and loom for sale? Lol
redcar
Post Fri Jan 06, 2012 8:41 pm
Yes i was offered 2 yesterday...
Just put a wanted ad up.
Best you hear it in the car running though so just be patient for one to come up i suppose.
Tay
Post Sat Jan 07, 2012 9:59 pm
drop a valver in it or a 2.5 would be far better for a trip to the ring..................
