Electrical suggestion/help
bigwinn
Post Fri Jan 06, 2012 7:34 am
Morning all
I'm planning to set up an alternative headlamp wash system, I have the bottles, pipes, jets etc, however I'm going to do away with the actual wipers and create a spray only system.
So, with that in mind, I will be a switch activated one from the dash. Where is the best place to run power from and splice into? I have the hlww loom in place in the car too. I won't be using a stalk switch either.
Thoughts and suggestins as to where to pull power from etc
TIA
Stu
Bronzit gone- she lives on
'89 325i auto touring: Malachite Green
Now, I'm no gynecologist, but I know a tw4t when I see one...
Post Fri Jan 06, 2012 9:23 am
Connect the black wire from the headlamp wiper motor on your headlamp washer pump to the purple/black that already goes to the two other pump motors, connect the other terminal of the headlamp pump motor (currently a brown earth wire) to your switch, and the other switch terminal to earth.
You won't find the low pressure existing pump very effective without wipers.
bigwinn
Post Fri Jan 06, 2012 10:30 am
Cheers B
How can I recreate high pressure? Higher rated pump?
Stu
