318 carb to 318i conversion
e30-EVN
Post Thu Jan 05, 2012 8:48 pm
A mate of mine is swapping out his old and very knackered 318 carb engine (m10 I think) and replacing with a 318i (m40).......
Reason for this is the doner car has this engine so this is what he wants to use.
As most of you know I'm no engine swap or conversion virgin but Is there anything I need to be aware of for doing this??
Carbed engine had no fuel return so planned swapping the fuel pumps around complete with fuel line ect but anything else you could think of would be useful. By this I mean not the obvious as I have it pretty much covered
Ant
Post Thu Jan 05, 2012 8:59 pm
Fuel tank needs swapping too
You will also need to fit the rear diff/fuel pump loom, plug is under the seat cable tied to the tube on the RH side
Check Pin 20 of the C101 before you connect a battery winkeye
You may also need to mod the C101 wiring a bit for the starter/unloader relay wiring
e30-EVN
Post Thu Jan 05, 2012 9:05 pm
Aw fukin hell..! Fuel tank.?........... That was unexpected lol
The car is on an E so pin 20 is prob a very good call there Dan 8)
Bit more involved than first thought then :mad:
Post Thu Jan 05, 2012 9:08 pm
Yep, unless your lucky and its been changed in the past for a tank that has the fuel pump pot? Just whip the RH cover off and pull the sender out to check
penton08
Post Thu Jan 05, 2012 9:12 pm
A few brackets in the engine bay might need swaping about, Rad mounts, AFM, ect. The bulk head trim will need swaping to hold the 4 pot wiring cover. You might need to re wire the rev counter/eco gauge too.
e30-EVN
Post Thu Jan 05, 2012 9:13 pm
It has fuel level on the pas side and fuel pump drivers side if that's what u mean??
Post Thu Jan 05, 2012 9:16 pm
I meant the M10 chariot, wont be anything on the pass side of the tank, just the pickup/level sender on the drivers side.
And the jobs Penton mentioned!
e30-EVN
Post Thu Jan 05, 2012 9:18 pm
Yeah Dan, I've looked in the m10 car and the pump is in the tank. Its not external......
Post Thu Jan 05, 2012 9:28 pm
Its not a pump on the M10, just a pickup tube, take it out and look in the bottom of the tank for a steel bowl spot welded to the bottom, if it doesnt have this the tank will need to be swapped
e30-EVN
Post Thu Jan 05, 2012 9:31 pm
Ah right sorry mate, pure thick moment there haha
Look tomoro. Nice1
