what sort of super mad ratio is this diff
craigieeb
Post Thu Nov 17, 2005 3:32 pm
iv just found a diff in my cupboard, it has no tag on it, so i rotated the input shaft, and it rotated the out put shaft once to EXACTLY 3 and a half turn's....???
anybody shed any light on this? i cant remember whether it came from a 320 or a 325i, (im sure it was a 325i) but i know the car was brought over from germany, a few years ago, so what sort of ratio could it be?
ta
(small case)
kam-325i
Post Thu Nov 17, 2005 4:33 pm
3.50:1 ?
craigieeb
Post Thu Nov 17, 2005 4:38 pm
bit of a strange ratio dont you think? i'v never heard of a 3.50:1 diff before
and how so i tell if it's an open or a slipper?? :?
i think im having a "blond" day
kam-325i
Post Thu Nov 17, 2005 4:54 pm
I've heard of a 2.93/4:1 ratio for an E30.
To check if its a slipper, give it me !!!!
Turn one of the output shafts with the input shaft locked(so it does not turn), if the other output shaft turns the same way, its a LSD, if it turns in the opposite direction, then its a standard diff.
Project_E30
Post Thu Nov 17, 2005 5:13 pm
I have a spare 3.64 or 3.46 cant remember :mad: which is not far off 3.5 so sounds like you have the same.
Post Thu Nov 17, 2005 5:35 pm
sounds like a 3.46:1 diff
both outputs will turn the same way if its an LSD
craigieeb
Post Thu Nov 17, 2005 5:41 pm
so what would that do on a 325, super speedy gearing but no top end? or just turn it in to a slug, and get 2000000 miles off Ԛ£10's worth of petrol
billgatese30
Post Thu Nov 17, 2005 5:46 pm
Slug...for super speedy you need a higher number, the lower the slower...gettit :cool:
craigieeb
Post Thu Nov 17, 2005 5:47 pm
gotit :cool:
Post Thu Nov 17, 2005 5:48 pm
erm i run a 3.25 on my 316i Auto which had a 4.45 originally and other than a slower take off its fine on the move would notice it less with a manual imo
small case wont put up with a 325i tho - it'll lunch itself soon enough
kam-325i
Post Fri Nov 18, 2005 10:24 am
so whats the "ideal" diff ratio for an every day, standard daily driver 325i ?
Simon
Post Fri Nov 18, 2005 12:55 pm
kam-325i wrote:so whats the "ideal" diff ratio for an every day, standard daily driver 325i ?
3.64
Dan318-is
Post Fri Nov 18, 2005 1:02 pm
i thought it was 3.91?
Simon
Post Fri Nov 18, 2005 1:05 pm
318-is wrote:i thought it was 3.91?
I'd much prefer the 3.64, as fitted to early sports, still gives good acceleration, and doesn't run out of steam, just fitted one to the touring, muchos improvement!!
gcorky
Boost Junkie
Post Fri Nov 18, 2005 1:22 pm
at 5000rpm in top ,what speed do you do ,im asking because ive just replaced my diff with a unit tagged 3.73(not sure whether its true like)and i show 120mph ,but car seems very low geared!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Simon
Post Fri Nov 18, 2005 1:24 pm
gcorky wrote:at 5000rpm in top ,what speed do you do ,im asking because ive just replaced my diff with a unit tagged 3.73(not sure whether its true like)and i show 120mph ,but car seems very low geared!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
If that's aimed at me, I'm not sure yet, as I'm yet to swop the speedo senders over because they were different, diff came from a pre-facelift. :oops:
gcorky
Boost Junkie
Post Fri Nov 18, 2005 1:27 pm
ello simon no just curious whilst your on ratios ,see what you lot get :D
craigieeb
Post Fri Nov 18, 2005 5:01 pm
im prety sure the one i have on is a 4.1 or something to that efect, and flat out in 5th the needle goes past the 150 marker, not sure how accurate it is but it feel's damn fast
(all done on an air strip of course)
