LSD bolt hanging out
StevE30
Post Wed Jan 04, 2012 10:02 pm
Its a bad picture but can anyone identify where this bolt has come from?
looks like it hasn't sheered off from anywhere. went bang over a bump and theres now a bolt sticking out of the rear casing.
still has drive as it was loaded on and off a trailer. Is it likely to have caused damage inside the diff or is it a case of a new back casing and its good to go again?
I bought the diff on here over a year ago but covered less than 4000 miles, do you think a bolt could have dropped in before I bought the diff and somehow it has managed to go this far without it happening? there were a couple knocks from the diff in the past.
FYI its a 3.25 ratio LSD.
thanks
Steve
MrBenn
Post Thu Jan 05, 2012 9:26 am
Isn't that the drain plug?
Sjoerd320i
Post Thu Jan 05, 2012 10:13 am
MrBenn wrote:Isn't that the drain plug?
Sure is...
Wouldn't drive it anymore as the diff is empty.
Demlotcrew
Post Thu Jan 05, 2012 10:45 am
Its hard to see from that photo,
The sump plug is normally much larger in diameter.
Your poly bush doesnt look too clever either!
Andrew
StevE30
Post Thu Jan 05, 2012 11:10 am
I've now got a better pic if it helps.
thanks
Demlotcrew
Post Thu Jan 05, 2012 11:16 am
That looks like a flange bolt. Only the crown has those holding it on. Without taking the diff apart i would not risk driving on it. You run the risk of locking the rear wheels if any more bolts drop out.
That said, there is very little room for them to simply drop out, so expect damage inside!
Take it off and have it rebuilt.
Andrew
Curr946
Post Thu Jan 05, 2012 11:18 am
I would be getting the back plate off get the inners washed out with some petrol then new back plate on with some fresh oil and crossing my fingers
If your wife must learn to drive, don't stand in her way!
MrBenn
Woah! That looks like one of the bolts from LSD unit has worked loose, dropped off and punched the drain plug off of the back plate!
Oops too slow, already been answered.
redcar
Post Thu Jan 05, 2012 11:29 am
what has happened to your polybush?
Duke137
Post Thu Jan 05, 2012 11:40 am
Yikes, looks fooked :clin:
craigieeb
Post Thu Jan 05, 2012 1:31 pm
StevE30 wrote:I've now got a better pic if it helps.
thanks
That's quite impressive,
Has someone been in there before you bought it, and had a bit of a fiddle....?
Or just a freak occurrence,
Either way it's fooked!!
Demlotcrew
Post Thu Jan 05, 2012 1:36 pm
I dont think its a goner, just needs to be inspected, you could repair that on the car!
Andrew
Tom_Maverick
Post Thu Jan 05, 2012 2:57 pm
does the diff have a magnetic drain plug? if so the bolt could have floated about in the case for a short while till it got stuck to the magnetic plug and then while things were turning 'stood up' against the drain plug over a bump or suchlike and just punched the whole plug and surrounding ally out..
StevE30
Post Thu Jan 05, 2012 8:20 pm
4 missing bolts and 2 on the way out. Looks like the only thing damaged is the speed sensor wheel which is now loose. How is this normally held in place?
The edges of the poly bush are broken too.
http://s72.photobucket.com/albums/i182/ ... -53-53.mp4
The person that put this together (bought off a zoner) should probably buy a new torque wrench with the money I paid for the diff.
Somehow it managed a trip to Gatwick and back like this. :o
thanks for the help.
Steve
Demlotcrew
Post Thu Jan 05, 2012 8:28 pm
The speed trigger needs to be heated up and pressed on as its an interference fit that keeps it on.
I would pull the diff and clean the bolt holes till they are dry and then use loctite to secure the bolts.
Its a pain but it looks like minimal damage has been done!
Andrew
Tom_Maverick
Post Thu Jan 05, 2012 10:04 pm
Lucky lucky! Thank Christ you didn't do more damage.. :)
Demlotcrew
Post Thu Jan 05, 2012 10:10 pm
I've just watched the video, it looks like the LSD is not working either, it should not be making that clicking noise, something is seriously damaged inside!
StevE30
Post Thu Jan 05, 2012 10:40 pm
Demlotcrew wrote:I've just watched the video, it looks like the LSD is not working either, it should not be making that clicking noise, something is seriously damaged inside!
Are you sure its not the speed trigger?
there is still quite a bit of resistance to turn the wheel with the other wheel on the ground.
Post Thu Jan 05, 2012 11:02 pm
There's also a stray washer on the left-hand output shaft coupling. :mad:
gareth
Post Thu Jan 05, 2012 11:52 pm
Ouch!
Right, that's not something i've seen before! To remove those bolts usually requires a 1/2" breaker bar and an extension! tight and retained with some strong loctite! I suspect it's been bodged together from two diffs to get a LSD in another ratio.
It's hard to pinpoint the source of the noise but it could be gear damage. Check the teeth on the crownwheel (the big gear you can see) carefully for any damage caused by the stray bolt. If there's damage, it's need a full rebuild with a new crownwheel and pinion. There's also a very good chance of bolt / casing fragments in the bearings.
PM on it's way :thumb:
Demlotcrew
Post Fri Jan 06, 2012 10:11 am
Apologies, i thought both wheels were in the air. That noise could just be the clutch pack working, but i have never heard it make that sound before.
I always heat the crown before its tightened down with the flange bolts and loctite. As the crown cools, it clamps the flange bolts and secures them in place, You cannot be sure otherwise.
I would not attempt to fix it in situ, Its not that hard to pull the diff apart to see whats going on.
Andrew
Post Fri Jan 06, 2012 10:32 am
One fooked LSD! :eek:
Demlotcrew
Post Fri Jan 06, 2012 10:35 am
Its one of the reasons why i would never use Polly on my car, it doesn't last very long!
redcar
Post Fri Jan 06, 2012 10:59 am
Demlotcrew wrote:Its one of the reasons why i would never use Polly on my car, it doesn't last very long!
Seems that this problem with the diff poly mount is quite common. It sags.
Demlotcrew
Post Fri Jan 06, 2012 11:04 am
Its not the best solution, its a solution that has been well marketed and is relatively inexpensive!
Kos
Post Sun Jan 08, 2012 1:28 am
i've been saying it for years that the polly bushes for diffs are crap and fail and cause more damage
Z3M diff bush is fine for any fast road car and track car.
Post Sun Jan 08, 2012 10:22 am
Kos wrote:i've been saying it for years that the polly bushes for diffs are crap
Extend that to include all bushes on an E30, and I fully agree!
Kos
Post Sun Jan 08, 2012 5:22 pm
Agreed
Ps, I sent you a pm ages ago, it's still in my out box !!!
Post Sun Jan 08, 2012 5:40 pm
Agreed
He is probably too scared to open it ! :eek: :)
Post Sun Jan 08, 2012 9:07 pm
Agreed
90 messages in my inbox, going back to June last year, Kos
None of them from you!
redcar
Post Sun Jan 08, 2012 9:36 pm
Brianmoooore wrote:
Kos wrote:
Brianmoooore wrote: Extend that to include all bushes on an E30, and I fully agree!
Agreed
I can only fit about 20 in my inbox :eek:
How about a solid aluminium diff bush?
kam-325i
Post Sun Jan 08, 2012 9:40 pm
solid would transmit stress's to the chassis.
The idea behind the rubber bush is to absorb some of the stress's.....
Kos
Post Tue Jan 10, 2012 8:36 pm
redcar wrote:
Brianmoooore wrote:
Kos wrote: Agreed
its out of my out box now......
redcar wrote: I can only fit about 20 in my inbox :eek:
team members have more inbox space than us commoners
