no heat in car
beefy
Post Thu Nov 17, 2005 5:11 pm
there is very little heat coming from blowers i have bleed the system until hot water came out of the bleed valve on thermostat housing. there is no bleed valve on radiator so couldnt bleed from there.
but still no heat from blowers i was thinking of back flushing the heater matrix so i would like to know which pipe is the inlet.
any help at alll will be appreciated
craigieeb
Post Thu Nov 17, 2005 6:57 pm
did you have the heaters on while you were bleeding?
this is the only way i have done this and it has allways worked, for me anyway
the 2 pipe's on the bulk head are,
top, goes to the back of the cylinder head,
and the bottom goes to the thermostat housing, so the bottom is the inlet
if thats the info you needed : )
massive
Post Thu Nov 17, 2005 7:06 pm
Faulty thermostat is the common prob
Giggz
Post Thu Nov 17, 2005 7:35 pm
Let us knw how you get on Beefy,as i have exactly the same problem! What a time to pack up huh? I just went and bought a new thermostat,thermostat housing with gaskets and blled nipple from BMW's.Total of about 125.00 inc other bits and bobs. My heat only comes when the car is moving?!!?
^stolen but not forgotten^
kam-325i
Post Fri Nov 18, 2005 10:21 am
craigieeb wrote: the 2 pipe's on the bulk head are,
Strange, mine are the other way round, bottom to cylinder head, top to thermo/expansion tank.
beefy
Post Sat Nov 19, 2005 12:29 pm
i have flushed the heater matrix out. and bleed the system again the heaters are alot better thanks for the help
