Hello, just wanted to ask for some helps.
My 318is doesn't idle properly, it idles too low when cold, sounds like is coughing and the engine vibrates/moves around quite a lot (sending vibrations through the whole car). It gets better when it warms up though, however, then goes to an idle of around 1000k. The idle is always inconsistent, when starting cold it doesn't start unless i give it some throttle and let it warm up. The problem is still there when warm, it hunts at idle.
The engine is smooth when past 1000RPM, no vibrations or anything, and when driving it pulls fine after 1k rpm.
So what i've done so far:
Eliminated any air leaks by fitting new genuine BMW intake manifold gaskets and throttle body gaskets.
New coolant temperature sensor
New ICV
New spark plugs
All of these didn't make a difference, and when testing the new parts they seemed fine.
I am wandering if it could be the crank position sensor or the cam position sensor, does my problem sound like these could be the culprit? Is there anything else i can test? Thinking it could be the AFM, I remember Brianmoooore helping me test this a while back on the m40, but i've forgotten the correct procedure.
Thank you.
318is not running right
I would say an air leak
Check rocker cover, All Vacume pipes etc
redcar
I've checked these they're definitely fine and there isn't an air leak.Alex wrote:I would say an air leak
I'm thinking it could the the crank or cam position sensor or even the AFM.
I don't know how to check these though.
redcar
Just tested the Crank position sensor, that's working as when i unplug it the engine cuts out immediately.
However, when i disconnect the Cam position sensor, nothing on the engine changes, it idles the same, and climbs the revs the same. But there is 1200ohms when i test the cam position sensor. Could this be a fault in the car's wiring somewhere.
i thought that the car wouldn't even be able to idle if there were to be no cam position sensor connected. Unusual that in my case it doesn't make a difference.
rix313
This is what my car runs like as I've no idle controll valve and have the throttle cable tightened up to keep the idle revs up when it's cold (otherwise it stalls). It does mean that (as you're experiencing) the idle when warm is really high, but this isn't an issue for me as it's a track car and doesn't spend much time idling.
redcar
what happens when you disconnect the cam position sensor on your car when it is idling?rix313 wrote:This is what my car runs like as I've no idle controll valve and have the throttle cable tightened up to keep the idle revs up when it's cold (otherwise it stalls). It does mean that (as you're experiencing) the idle when warm is really high, but this isn't an issue for me as it's a track car and doesn't spend much time idling.
redcar
The brand new spark plugs i put in a few days ago are now quite black.
BEERBOY123
I've a slight cough at idle on my iS, just every ten seconds or so. Tried everything so am going to book it into Park Lane Classic next year and get them to have a look! Drastic measures!
Two headblenders, couple of bags of MC Hammer, 5 litres of FFF, a 48ft bastard, a box of jumped-up custard and some soggy chimps
redcar
Cool, let me know how it goes!BEERBOY123 wrote:I've a slight cough at idle on my iS, just every ten seconds or so. Tried everything so am going to book it into Park Lane Classic next year and get them to have a look! Drastic measures!
Thinking of taking mine to BMW as well, have no idea what could be wrong with it, maybe the engine is just absolutely knackered... Still pulls alright.
Gonna get it all roadworth and take it for a longer trip on the road and see if there are any more faults which could give a pointer as to what is wrong. Just idles like absolutelely awful.
BEERBOY123
Mine pulls like a train, 0-60 eight seconds no probs (unmodified, and I weigh very little...) but the slight idle cough annoys me when I'm stationary, so I want to get it looked at. I think it's a gasket thing, but it's beyond me, so I'll let them take a look and put my hand in my pocket if I have to. I'll report back, but it won't be until March.
