johnono
Post
Thu Nov 17, 2005 3:42 pm
under the bonnet of a mates 323i the other day,..
noticed his motor looked like a fair few bits and peices were missing!
is it me or do they usually look like this?
any help appriciated
dazleeds
- old skool raver
Post
Thu Nov 17, 2005 3:54 pm
heres my c plate 323 bay
johnono
jonb
Post
Thu Nov 17, 2005 4:38 pm
johonno
nothing missing from there.....welll apart from a proper engine.
Gwynleym10
Post
Thu Nov 17, 2005 4:39 pm
Its wierd because its a 323i and still going....not rusted away!
craigieeb
Post
Thu Nov 17, 2005 4:41 pm
jonb wrote:johonno
M50 Turbo!!!
I shall say no more
kam-325i
Post
reminds me of my old 320i engine.
e30alpina
Post
Thu Nov 17, 2005 4:54 pm
jonb wrote:johonno
so whats wrong with a 2.3 engine ?
craigieeb
Post
Thu Nov 17, 2005 5:18 pm
well it's like the "middle child" isn't it, not a whole lot better than a 320i, and not as good as a 325i.
M50 Turbo!!!
I shall say no more
e30alpina
Post
Thu Nov 17, 2005 6:41 pm
what if you put the 2.3 head onto the 2.5 block
stevetigger
Post
Thu Nov 17, 2005 6:44 pm
craigieeb wrote:well it's like the "middle child" isn't it, not a whole lot better than a 320i, and not as good as a 325i.
My 323i killed 320's and it kept up with 325's to about 120mph, I have had loads of sport's so I should know, im sure other people will agree!!
craigieeb
Post
Thu Nov 17, 2005 6:46 pm
so your saying a 323 is on the same par as a 325i.
ok.
M50 Turbo!!!
I shall say no more
e30alpina
Post
Thu Nov 17, 2005 6:51 pm
the 323 is a very quick motor , but a engine with 2.5 block with a 2.3 head is ment to be quicker than a standerd 325
Simon
Post
Thu Nov 17, 2005 6:54 pm
Johnono, it's probably the lack of power steering that's making you think something's missing?
Post
Thu Nov 17, 2005 7:06 pm
A 323 head (731 casting) will not fit on a 325 bottom end , the piston crown will actually prevent the head from being bolted on as it is not compatible with the 731 combustion chamber.
e30alpina
Post
Thu Nov 17, 2005 7:21 pm
pacerpete wrote:A 323 head (731 casting) will not fit on a 325 bottom end , the piston crown will actually prevent the head from being bolted on as it is not compatible with the 731 combustion chamber.
ok thanks for that, just something i herd.
johnono
Post
Thu Nov 17, 2005 8:08 pm
Simon wrote:Johnono, it's probably the lack of power steering that's making you think something's missing?
cheers fella
, i looked at it last week for a "danish brother" and was taken aback but the apparent emptyness of his engine bay
glad to see its all as it should
: you can all keep "debating" now
stevetigger
Post
Thu Nov 17, 2005 8:13 pm
craigieeb wrote:so your saying a 323 is on the same par as a 325i.
ok.
I never said the same par, look in the photo's...I have had the lot. What I said is that it's not far behind, do you really think .178cc makes that much difference?? 0-60 is like a second difference which in the real world is nowt, and top end is ten miles an hour which I did say you can tell.
