e30 cab water leak
e30121
hi there i have a problem with water leaking into the footwell behind drivers seat of my cab cant see any obvious signs of where it is coming from-should i change all the window seals just to be safe if so would i have to get them from the dealers and how much roughly thanks
Rtaylor2208
Sounds like blocked drainage holes in the horseshoe mine was the same.
best method I found was to get a long pice of wire like a coat hanger and poke about near the lowest part of the horseshoe where the frame attaches to the body. Pour some boiling water in afterwards to make sure it drains out the holes on the cills. I had to repeat this a few times to clear mine as they were pretty gunked up.
Also take the wet carpet out if you can and dry it out as the carpet will never dry out otherwise and the floor will rot.
