Gear linkage
biggill
Post Tue Jan 03, 2012 5:42 pm
Hello there, i have a 325i convertible manual 1989 and the gear linkage is on it's way out(load's of play), i have been told you can put a z3 short shift in which is better.
Was wondering if this is true and would anyone be able to tell me all the part's i need and how much it should cost on part's?
Thank you.
kam-325i
Post Tue Jan 03, 2012 5:50 pm
All info here Dude....
http://www.e30zone.net/e30zonewiki/inde ... conversion
And Welcome to the Zone....... :D
Post Tue Jan 03, 2012 8:21 pm
A Z3 1.9 gear lever is considered by most to be a worthwhile upgrade, but this in itself won't sort out your sloppy gear linkage.
The most likely part to be responsible for most of the play is the bush in the joint that fits onto the selector shaft from the gearbox. The length of this bush was increased on later cars, so the connecting shaft to the gear lever will have to be changed to suit, if a longer replacement is supplied, or changed anyway, if it shows signs of wear.
biggill
Post Tue Jan 03, 2012 8:33 pm
Thank you very much. I was thinking of changing the whole linkage arm.
Post Tue Jan 03, 2012 8:44 pm
http://bmwfans.info/parts/catalog/E30/C ... g_parts-2/
# 13 is the main culprit, but 10, 11, 2, 8, 6 and the gear lever can all make a contribution.
biggill
Post Tue Jan 03, 2012 8:52 pm
I am getting mixed review's on this, i was informed the z3 jobbie is cheap way of doing it and when going into reverse and first you will hit the console everytime.
Would it be best to keep it original?
I know it's personal prefrence but would love to hear what you guy's have to say.
RoadHazard
Post Tue Jan 03, 2012 9:11 pm
I'm not running the Z3 shifter but I used to have the problem with the current shifter (E36 M3) hitting the console when going into reverse. I fixed it by turning the shifter 180 degrees (front to back.) Could it possibly be the same problem for those guys?
Post Tue Jan 03, 2012 9:28 pm
I refurbed mine using all standard parts - one of the most fiddly and frustrating but satisfying E30 jobs I've done.
The standard shift is great when its all "tight" as it should be.
You might need a new lever anyway as the bush in the end of the lever wears out.
http://www.e30zone.net/e30zonewiki/inde ... ar_Linkage
biggill
Post Mon Jan 09, 2012 9:56 pm
Thank you very much lad's, i'm going with the z3 short shift will keep you informed.
