Hi everybody and best wishes to you all.
Hope this thread is ok here. I need to get hold of some new rubber/plastic cut outs for the ends of the cam cover/head on my 325 M20 engine '87. As you know there are 4 in total. Mine have leaked since i've owned the car, and every time the tappetts are checked, or if the cam cover is off, no amount of 'gumming up' works in stopping these little blighters from leaking. I finally want to try and stop this, however BMW main dealer have told me they can't get them! Their diagrams don't have them highlighted as a part(s). Does anyone know of any other source for these. Any help much appreciated.
Paul
M20 engine rubber cam cut outs
jesmond
Ask them to look up 11331264519
http://www.realoem.com/bmw/showparts.do ... g=11&fg=25
This should be what you need.
jesmond
Ah, thanks for that, I've seen that diagram, but it's the half moon cut outs i'm after. There are 2 each end of the cam cut out of the head
E30SPORTMAD
Think i have some spare in a head set that i used other gaskets from, can check tomorrow
This diagram is exactly what your BMW dealer brings up on their parts screen. They are either idiots or plain lazy!capri_rob wrote:Ask them to look up 11331264519
The "half moon cut outs" should be p/n 11331264519jesmond wrote:Ah, thanks for that, I've seen that diagram, but it's the half moon cut outs i'm after. There are 2 each end of the cam cut out of the head
jesmond
But they aren't.
Rob, are you then saying that you would expect to see the cut out's that i've described, as being the 'blind plug' p/n 13 - 11331264519 on the diagram? Because if so, then the diagram is wrong, and I should just order this part number. But, otherwise, to me this looks like completely the wrong part.
I wish I could draw them, but they are all individual. There are 2 either end, and they are made of black plastic or rubber, and are arch shaped or half moon as it were. If you've done a cam gasket before you may not even have noticed them, but they come out of their 'seats' and are about 35m tall by about 25m wide. Imagine the arch sized window shape in 'Playschool' and you're there! Don't know if you're as old as me and can remember such things lol.
Any further thoughts guys much appreciated.
Paul
But they aren't.
Paul
lamby
that is them,blind plug number 13,parts don,t always look the same on drawings.i ordered them for mine and exactly right.two each end next to each other leaking oil.
jesmond
Ar, you beauties, thanks guys. I'll order with confidence.
Good old zoners do it again!
Hope to be back soon.
Paul
Paul
